Old 03-10-2014, 10:47 AM   #1
whizzernick
whizzernick's Avatar
Default 1933 fuel guage
Here is what I hope is a simple solution to my problem . my 1933 fuel gauge has got all kinds of gunk and staining of the gas gauge glass tube. The glass tube that you see the red fluid that shows the amount of fuel in the tank. I can clean the glass tube from the top. My question is what kind of chemical can I use to unblock the copper tube that goes from the filler or where the air tube connects to the gauge to the gas gauge glass tube. I don't want to ruin the glass. I'm wondering if phosphoric acid would clean the gauge and that tube without staining or etching the glass. are there Any other methods or chemicals that might work.
whizzernick is offline   Reply With Quote
Old 03-10-2014, 11:29 AM   #2
jkeesey
jkeesey's Avatar
Default Re: 1933 fuel guage
Lacquer thinner should work.
jkeesey is offline   Reply With Quote
Old 03-10-2014, 11:34 AM   #3
deuce lover
deuce lover's Avatar
I have used acetone.I have heard that brake clean works also.Scrubbing in the tube with cotton rolled around thin wire gets it really clean.
deuce lover is offline   Reply With Quote
Old 03-10-2014, 12:15 PM   #4
Terry,OH
Terry,OH's Avatar
I have used Lysol toilet bowl cleaner, without any effects on the glass. If you can get any through the small line it will most likely open, if zero flow from the tank to the glass, it may not open. The acetone does clean the glass and remove the old red deposits.
Old 03-10-2014, 01:47 PM   #5
FlatheadTed
FlatheadTed's Avatar
I suggest you straighten it out and drill it ,
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 03-11-2014, 10:28 AM   #6
whizzernick
thanks for info. now one more question. I am also working on a temperature gauge actually a 1932 dual temp. The fluid in the temperature part is not red. It is almost clear. It seems to work properly as it goes up and down with heat and cold. I was told by someone who repairs them that the fluid that was originally used causes cancer. For that reason he doesn't repair them anymore. The temperature gauge I'm speaking of has a screw in the bottom of the temperature probe. I assume that it's like that because of the repair. I'm wondering is there a way to tint fluid? Also does anyone know who repairs these now? Thanks for any help.
Old 03-11-2014, 01:27 PM   #7
rotorwrench
rotorwrench's Avatar
The red dye used doesn't last a very long time. The ultraviolet light from the sun will degrade the color. Ther are several threads on this subject. You might try a search to find some of them.
Old 09-17-2014, 03:52 PM   #8
johnschultz
source for "red" fluid and copper fittings for 34 fuel guage and other
"hydrophonic" guages. A&L parts, 196 albany turnpike, Canton, Ct. 06019
860 693 0112 $18
johnschultz is offline   Reply With Quote
Old 09-18-2014, 12:00 AM   #9
34ford
34ford's Avatar
get a nos one from me 60.00 + 6.00 shipping in the u.s.
34ford is offline   Reply With Quote
Old 02-07-2015, 02:22 AM   #10
fourfords
fourfords's Avatar
860 693 0112 $18
I think you might mean "Hydrostatic"
fourfords is offline   Reply With Quote
Old 05-15-2015, 09:25 PM   #11
morrisgauge
The temp can be rebuilt, but the current fluid cannot be re-tinted. A full fluid change must occur. As for the fuel gauge, a mild acid helps to free the dried residue from the original fluid, but there could be several chemical steps depending on what your gauge has in it. You may be best to buy the NOS unit.
www.morrisgauge.com
morrisgauge is offline   Reply With Quote
