07-16-2016, 01:08 AM | #1 |
Clutch query
Hi,
Just got towed home the last 500 metres. Clutch issues. Yesterday I had the car with a mechanic and he mentioned he tidied a few things up. I should have asked what he had done but it was wet and windy and I just wanted to get home. I suspect he may have fiddled with the clutch adjusting arm; the was no free-play when I got the inspection plate off just now. There are two photos attached of the view in the inspection area with the clutch at rest and fully depressed. It appears that there is only 4mm of movement. How much movement should there be? Just before I rolled to a stop I had no power in 2nd or 3rd and minimal movement in 1st. Reverse seemed to be working a little. Clutch burning smell though not great and quickly disappeared. Any thoughts on what I need to do next? Cheers John |
07-16-2016, 03:54 AM | #2 |
Re: Clutch query
You need to adjust the rod on the clutch pedal so you have about 1" of freeplay at the pedal.
Hopefully you haven't damaged the clutch. Did this just start after someone messed with it? Or did it happen while driving? |
07-16-2016, 04:49 AM | #3 | |
Re: Clutch query
I drove 12 kilometres home last evening from the mechanics garage - noticed nothing amiss - I went slower than I would normally as it was windy, wet and foggy. This morning the car drove fine for a few minutes (about 2 kilometres or so) and then I noticed the smell, the slipping etc. Turned around and almost made it home before a steep hill on a curve stymied my efforts. Cheers John |
07-16-2016, 05:22 AM | #4 |
Re: Clutch query
ck the clutch arm it may have cracked that just happened to me if it cracked peddle feels soft and no clutch
kevin 1930 tudor |
07-16-2016, 05:46 AM | #5 |
Re: Clutch query
Did you notice a lack of pedal free-play as soon as the mechanic was through with it ? It sounds as though the clutch has been 'adjusted' so it is partially disengaged. No free-play at all.
Hopefully an adjustment to allow the proper free-play as Tom mentioned will correct the problem. |
07-16-2016, 09:09 AM | #6 |
Re: Clutch query
07-16-2016, 11:44 AM | #7 |
Re: Clutch query
While you have her opened up, you might consider shooting into the clutch with a couple of cans of Brake Clean, while someone rotates the engine with the crank.
Use Caution Here: That Brake Clean stuff is highly carcinogenic, and explosive. Don't breath the vapors. Do it outside and wear a good type of paint mask. Don't use an ordinary dust mask. Lots of clutch residue will be washed out into your catch pan underneath the car. |
