02-12-2016, 04:13 AM | #1 |
No, this is not another "My car won't start" thread....
Well, my car won't start but I know the reason why. It has been covered in so many threads before.
I have a problem with grounding in the distributor. Yes, my points are open, and yes, I know to screw out the reproduction ignition cable. Problem is that the cable only ceases grounding when I have about a half turn left. This is of course problematic and not satisfactory. I have a replacement cable winging its way to me but I was wondering if anything can be done to correct the problem with the cable I have. Tomorrow is a tinkering day and I have little else to do (other than domestic chores ). In all those other threads the problem was identified and a solution was suggested - ie screw the cable in only 1 or 2 turns, but I could not find any mention of being able to repair the cable or to modify the cable to prevent the grounding. Is this indeed possible? Has anyone attempted it? Thanks John |
02-12-2016, 06:58 AM | #2 |
Re: No, this is not another "My car won't start" thread....
Hi John,
Some of the problem may also be with the weak bus bar of the lower plate that the conductor of the cable contacts, if the cable is threaded in too far, it deflects the bus bar into the housing. I had this happen to me. Glen |
02-12-2016, 08:12 AM | #3 |
The cable does not need to be grounded.... It's just a housing for the inner wire to make contact on the buss bar. As Glen mentioned if it is screwed in to far it pushes on the buss bar and grounds it on the distributor housing. There is usually nothing wrong with the cable unless it has an internal short to ground...you can run a jumper wire in place of the cable or ohm test it to prove it out
02-12-2016, 08:14 AM | #4 |
I think it is the lower plate more than the cable. Is there room to put a pice of rubber behind the clip on the lower plate to stop the ground.
02-12-2016, 09:16 AM | #5 |
You need to determine if the problem is inside the distributor, or in the cable.
I've seen repro lower plates that are much thinner metal than the originals, and this can lead to bending and shorting to ground. I've seen frayed wires inside the cable, so when the spring loaded brass contact is pushed back it shorts to ground. I use an ohm meter and connect to the brass button and the outside of the cable. Be sure the switch is ON because originals connect the brass contact to ground when in the OFF position. I then push the brass contact in and out and also flex the cable. At no time should there be contact to ground. If the wire shows continuity to ground, then remove the inner wire and install a new one. |
02-12-2016, 09:38 AM | #6 |
02-12-2016, 12:32 PM | #7 |
Plus if that fiber washer is missing the screw might bottom out in the condenser before the condenser is tight to the lower plate. This can cause the condenser terminal to spin and ruin the condenser.
