01-15-2021, 05:52 PM | #1 |
33 gauge panel in a 34
i am buying a 34 and i want to install a 33 gauge panel complete in the car. is it just a matter of cutting out the center and installing the 33 bezel or do you have to do body work in order to make it fit
01-16-2021, 12:56 AM | #2 |
Re: 33 gauge panel in a 34
Actually the glove box opening in both yrs is the same as a '33 guage panel opening. Once we welded one [glove box opening] into a '34 dlx dash and then could use the '34 ash tray. Has to be a no gap fit for a good tig weld. The '33 trim ring hides the joint. Newc
01-16-2021, 07:55 AM | #3 |
so i cannot just cut out current 34 gauge panel and fit the 33 pnael in
01-16-2021, 07:59 AM | #4 |
I don't think so.Lots of work even if you have the skills.IMO find a '33 dash and switch it out then sell your '34 dash.Here is a pic of the glove box opening.You can see the flange you need to create to accept the '33 instrument panel and bezel.
01-16-2021, 08:00 AM | #5 |
thanks
01-16-2021, 09:51 AM | #6 |
01-16-2021, 10:06 AM | #7 |
thanks ill watch for one
01-16-2021, 10:55 AM | #8 |
Early 34s also had the removable insert like this one I have. Mike are you looking for a standard or deluxe?
Wanted flathead speed equipment Thanks |
01-16-2021, 11:18 AM | #9 |
deluxe cabriolet
01-16-2021, 11:24 AM | #10 |
Sweet!
01-16-2021, 11:35 AM | #11 |
I had the same issue. Want to do the same. I considered doing the same as I have a perfect 34 dash. No holes drilled with good graining but not perfect. The hard part is aquiring the Bezel that holds everything together. I am going to make gage panel myself. I am using S&W Winged gages. Its a pain in the ass, but I think in the long run its worth it. Good luck. Stan
01-16-2021, 11:37 AM | #12 |
i have a complete 33 gauge panel with the bezel now i just need to figure out how to put it in a 34 dash with good woodgraining
01-16-2021, 11:58 AM | #13 |
I would say you can weld in a panel like this one but your gonna mess up the woodgrain. On my 32 I didn’t run the gauge tunnel and machined a 4 blocks that acted like wedges on the back of the original dash panel.
In fact I will trade you my 33 pheaton for your 34 cabriolet like you offered 20 years ago so you can use your 33 insert...
01-16-2021, 12:00 PM | #14 |
dont have the 34 cabriolet yet waiting for it to be shipped need windows if you know of anyone i have a 35 cabriolet project for sale together and running
01-16-2021, 12:09 PM | #15 |
33 Gauge Panel
01-16-2021, 12:09 PM | #16 |
thanks for the pix
01-16-2021, 01:35 PM | #17 |
I've got a 34 RHD dash panel. Might it be useful for this?
01-16-2021, 04:14 PM | #18 |
i dont know i will check
01-28-2021, 09:44 PM | #19 |
Cabrio is a completely different dash board.
yes, the opening has a return and mounting holes, just cutting the hole will not do |
01-29-2021, 01:11 AM | #20 |
Remember the '33 ash tray is different and rare. A modified '34 dash would fill your need just find the '33 parts and a glove box hole. wood grain would suffer from welding. 34 ash trays were repoped at one time. Newc
