12-06-2020, 06:45 AM | #1 |
6 volt load test
Good morning All,
I'd like to know how to set up a load test something like when a battery is tested. I went crazy for months trying to figure why my car wouldn't start. Once in a while it wouls start right up just as i lifted off the start button. It was as if there was not enough juice for the ingnition while it was cranknig. Finall i found it was the ignition switch which was warm to thetouch after running for a while. I think if an electrical load could be applied along with the multi meter it would show a dropin voltage while testing the ignition switch. Thanks for your thoughts. Al |
12-06-2020, 08:37 AM | #2 |
Re: 6 volt load test
Just to be clear, your question is: Is there a way to use a multimeter to test whether a given component (ignition, lights, horn, brake light) is shorting/grounding when activated? In other words the component itself is "working" but it's sucking power out of the circuit when it's on. Is that what you're asking?
12-06-2020, 09:08 AM | #3 |
A simple ohm reading with a decent meter will tell you what you want to know. The problem is that many times electrical issues are intermittent - you won't find it until you test it on a day it's acting up. That can slow down the detective work to find the problem.
12-06-2020, 09:13 AM | #4 |
I found that a voltmeter replacement or in addition to the ammeter on my car was more helpful. I can see the battery voltage with no load, when running the starting motor, with the ignition or lights on, or when the battery is being charged. As far as testing something like the ignition switch, just measure the voltage across it when operating. That will tell you a lot about whether it is bad or not. If you know the current you can calculate the resistance using Ohm's law.
I found a bad battery using the installed voltmeter. It was only 10 years old.
12-06-2020, 10:16 AM | #5 | |
Mechanical contacts arc and weaken with time, requiring an occasional Fonzie bump to make them work properly. |
12-06-2020, 11:24 AM | #6 |
Might also clean the terminals/grounds and do a load test on the battery. Just checking it's voltage may not tell the whole story.
12-07-2020, 06:14 AM | #7 |
I recently discovered that my car's starter cable was smaller than a #4 AWG, so make sure yours is a #1 AWG at least.
