08-05-2018, 07:09 PM | #1 |
spark plug sump plug
Not Model A but the picture says it all!
08-05-2018, 07:15 PM | #2 |
Re: spark plug sump plug
I have one of those on the exh of the 33 to plug the O2 sensor port,sure gets some interesting questions.
Lawrie |
08-05-2018, 07:20 PM | #3 |
I can only imagine the BS you tell people silly enough to ask.
08-06-2018, 09:53 AM | #4 |
Lawrie, you could tell them it is to burn the residual gas in the exhaust like having an afterburner for more pep.
08-06-2018, 10:25 AM | #5 |
Well I can see why the car isnt running correctly. With the porcelain cracked that bad it would provide an intermittent spark.
08-06-2018, 03:06 PM | #6 |
08-06-2018, 04:53 PM | #7 |
You'll never have to ask whether the plug was oil fouled or gas fouled.
Bob |
08-06-2018, 06:24 PM | #8 |
A big problem with that is that the lead has come off!
08-06-2018, 07:56 PM | #9 |
I need a 1/2" pipe plug to close off a gas line in my house so I used a Model T spark plug.
08-07-2018, 12:14 PM | #10 |
I've seen oil pan drain plugs, drilled & tapped for a DRAIN COCK! Kinda' SLOW, but it works!
Bill Dribble
