Old 04-24-2016, 06:46 AM   #1
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
Default fuel pump stand pipe thing
How do I expalne this thing. The pipe that goes under the fuel pump stand about 2in. dia. has baffel plates, have 4 in. ones and 5 in. ones. I need a 4 in. one because I have a 37 aluminum intake and the rear is 1 in. shorter. I'm sure by now you guys have figured what I'm talking about. Anyone know where I can get one? Thanks Walt
Walt Dupont--Me. is offline   Reply With Quote
Old 04-24-2016, 07:19 AM   #2
34billct
34billct's Avatar
Default Re: fuel pump stand pipe thing
Try Kenct on EFV8 site
34billct is offline   Reply With Quote
Old 04-24-2016, 07:21 AM   #3
Bored&Stroked
Bored&Stroked's Avatar
I think that Mac VanPelt mentioned he has them - hopefully he does. I call it a crankcase breather baffle - who knows it's real name!
I think back on all the flatheads I've torn apart (in the 37 - 48 vintage) - they rarely have these installed. I've pondered this recently and if you really look into how the crankcase breathing system works, it sure appears that this baffle is very important to help direct air down into the crankcase. Without it, it sure looks like the air will only move across the valley. I installed one in the 42 Merc engine in my 32 - first time I've ever used one!
D
Old 04-24-2016, 07:26 AM   #4
JM 35 Sedan
JM 35 Sedan's Avatar
The attached pictures show both the short and long oil baffle tubes that were used to help keep excessive amounts of oil from splashing up into the fuel pump mount/oil filler tube, and engine breather stand.
John
Old 04-24-2016, 08:05 AM   #5
1934
1934's Avatar
Walt, is this what you need?
1934 is offline   Reply With Quote
Old 04-24-2016, 08:14 AM   #6
Bored&Stroked
That looks like it to me!
Old 04-24-2016, 02:11 PM   #7
Mac VP
Mac VP's Avatar
We've got them. Basic part number is 6756. Here's the webpage
http://www.vanpeltsales.com/FH_web/e...prices-pg3.htm
VANPELT SALES LLC
Cincinnati, Ohio
Office: 513-724-9486
www.classictransmission.com
Mac VP is offline   Reply With Quote
Old 11-06-2016, 12:43 PM   #8
Steves46
Steves46's Avatar
Does the fuel pump stand gasket go on before this part?
If it aint broke, don't fix it!
Steves46 is offline   Reply With Quote
Old 11-06-2016, 01:28 PM   #9
deuce_roadster
deuce_roadster's Avatar
Yes, onto the manifold, there is a recess in the fuel pump stand for it.
Old 11-06-2016, 02:15 PM   #10
oldford2
oldford2's Avatar
Walt,
I have a 5" one I can give you. It has 3 baffles in it and if you cut an inch off it would still have 2 baffles which may be OK?
John
oldford2 is offline   Reply With Quote
