10-10-2020, 06:54 AM | #1 |
41 ford choke & Throttle Rod rubber connections
What is the best way to attach the new rubber
Connections to the existing rods. The originals Are crimped on. I've cut those off and am thinking about using epoxy Thoughts? |
10-10-2020, 07:48 AM | #2 |
Re: 41 ford choke & Throttle Rod rubber connections
I have a buddy that used JB on them. Looks stock and works well.
I used a hydraulic cable crimper for some yacht wire balustrading I did a while back. Worked well but left hex crimp marks on the joints if thats a worry for you. |
10-10-2020, 08:53 AM | #3 |
Thks unfortunately I don't have one. Of those the side that connects 1to the carburator arm I did in a vise 1 and it should be fine it's the side on the cable side I'm debating best approach
10-11-2020, 04:23 AM | #4 |
