08-09-2019, 01:32 PM | #1 |
Engine Ground Strap
Where can I get a braided engine ground strap 15" - 18" in length? Haven't found any this size at the usual Ford parts places.
And what does the 12 4 stamp on the end refer to? Thanks,
Kerry |
08-09-2019, 01:52 PM | #2 |
Re: Engine Ground Strap
These straps are readily available at auto parts stores:
https://www.google.com/search?client...+15%22+-+18%22 |
08-09-2019, 02:00 PM | #3 |
Thank you...I should have done a specific search...I see they are available at Summit. What does the 12 4 stamp refer to?
Kerry |
08-09-2019, 02:05 PM | #4 |
Sorry, I don’t know what the stamping is indicating.
08-09-2019, 03:04 PM | #5 |
My guess 12” 4 g
08-09-2019, 03:39 PM | #6 |
Kerry |
08-09-2019, 03:58 PM | #7 |
Suggestion: When grounding an old Ford consider fastening ground straps together and have them contact motor/ Frame in more than one area.
08-09-2019, 05:54 PM | #8 |
Just for the heck of it "mike" the thickness and then check it against this chart.
http://www.advantagefabricatedmetals...ndecimals.html Here's one that's 18/4. The 4 means 4 gauge. https://www.speedwaymotors.com/Taylo...ong,73424.html |
08-09-2019, 06:22 PM | #9 |
Hi 19Fordy,
I’m thinking it may be a 4 gauge wire equivalent strap, i. e. Enough cross sectional area to be ohm resistant equivalent. |
