Old 01-20-2021, 12:22 PM   #21
cas3
Default Re: How To Remove Cosmoline
LOL good one GB !
Old 01-21-2021, 04:45 PM   #22
Jim in Wisconsin
It would make a great name for a convenience store.
Jim in Wisconsin is offline   Reply With Quote
Old 01-22-2021, 06:04 PM   #23
aussie merc
aussie merc's Avatar
jet fuel and brass brush
aussie merc is offline   Reply With Quote
Old 01-23-2021, 09:02 AM   #24
rotorwrench
rotorwrench's Avatar
Originally Posted by tubman View Post
After seeing all of this, I guess I was lucky that nobody was able to deliver on the "Harley 45's packed in Cosmoline" they talked about when I was in high school.
I have an old 45 (WL) that was made in 1948 so I scoured this country and a few others for parts over the years for that restoration. Front cylinders seemed to have survived many years in cosmoline but the rear cylinders, not so much. It seems that large crates of rear cylinders were compromised by moisture and few survived. New cylinders are available now but for many years the rears were hard to find. I've only seen a few photos of a single WLA in a crate. I think it was the last survivor of the WWII era and the fellow was leaving it that way just for posterity and collector value. He'd had insane offers to sell the thing but I don't know what the status is on it now.
Old 01-23-2021, 10:06 AM   #25
KiWinUS
KiWinUS's Avatar
Tom you have had a lot of answers to your question but I have the easiest solution to your question. I would gladly come & remove your cosmoline complete with block. Problem solved.
Cheers
Tony
Old 01-23-2021, 02:26 PM   #26
Gregger Rod & Custom
Gregger Rod & Custom's Avatar
Thank you everybody!
I finally managed to find a NOS sector shaft and the cosmoline has really stuck and hardened on over the last number of decades.
This is the exact info I needed,
Gregger
When you turn on your car, does it return the favour?
Gregger Rod & Custom is offline   Reply With Quote
Old 01-27-2021, 08:31 AM   #27
Dak Rat
My 2-cents worth: I had a NOS crank pulley packed in cosmoline and wrapped in some kind of paper. Hard as a rock. I put it in an old crock-pot with a mixture of 50% purple power from walmart and water. Put it on high temp, and dropped it in. 20 min. later I fished it out and it was as clean as a hounds tooth.
Dak Rat is offline   Reply With Quote
Old 01-27-2021, 09:52 AM   #28
35fordtn
35fordtn's Avatar
Take it to a machine shop, spent $50 have them bake it.
We have a heated parts washer cabinet at our shop that works well, but not as good as baking it would.
Watched a local Model A guy clean a rearend housing covered in gooey oil. he covered it in diesel and lit it on fire, seemed to work well
Old 01-27-2021, 06:53 PM   #29
cmbrucew
cmbrucew's Avatar
GB would likely do it that way, but with drain oil.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 01-28-2021, 11:32 AM   #30
GB SISSON
GB SISSON's Avatar
Bruce
Waste not, wan't not.....
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson)
