08-12-2011, 09:49 PM | #1 |
Chasing rear axle threads/
I'm at the point of finally finishing my brake job and need to a die to chase the threads on the outside of the axle. What size die is necessary, diameter and thread? Thanks
08-13-2011, 12:11 AM | #2 |
Re: Chasing rear axle threads/
Do not use a die! A die will cut off the metal in the way leaving much weaker threads. You need to use a rethreader. A Rethreader moves the metal back into place.
08-13-2011, 01:43 AM | #3 |
Take a good axel nut, cut it in half, and clamp it on the inner good threads, than back it off to realign the threads.
08-13-2011, 06:46 AM | #4 |
Get a thread file and lightly dress the threads.
You have to be careful with Model A threads. Ford used tighter standard threads. In many cases if you chase the threads with off the shelf tap or dies you will find a small amount of metal taken off. The nut will then be much looser. Try taking a good Ford nut and compare it to a modern nut. You might be surprised at how much looser the modern stuff is. You also have realize many nuts on the A are HARD. Take a file to some of the nuts and you may be surprised how many barely get a scratch. I no longer use tap and die on A threads. I hand clean with picks on the inside threads and wire wheel the outside threads. I dress bad threads with a thread file. |
08-13-2011, 07:51 AM | #5 |
Hi Noyo, To answer your question, the thread on your rear axle is a 5/8 - 18 NF class 3A thread. If you can get a hold of one, use a hex body thread restoring die as Mike suggested above. The other method is to use an adjustable die, opening it up as much as it will allow - then try your nut (is the nut in good shape?) - then allow the die to close a little - then try the nut again, etc. until you have a close fit. Your nut should be a grade 8 or class C nut at the minimum. Happy Motoring!
--------------------------- www.burlingtoncrankshaft.com |
08-13-2011, 12:45 PM | #6 |
Charlie Stephens |
08-14-2011, 06:25 PM | #7 |
Thanks guys!! I managed to recut with the nut. one axle had grunged threads on the end so went pretty easy. This was the axle I replaced. Somewhere along the way--way back when( before 64 when I got it ) some had put the drum/hub on with about 1 inch of key needless to say, it failed and wore a grove about 1/2 way through the axle. JUNK
08-14-2011, 10:30 PM | #8 |
You come up with some of the coolest stuff!
08-14-2011, 11:07 PM | #9 |
The original axel nut was a special hardened nut ( refer to Dealers Price Lisr ) ; the rear drum axel nut should be torqued to at least 80 lbs or more to line up cotter key hole.
Like previously said by others, do not use a standard die to chase the threads on the axel. Ron |
08-15-2011, 09:52 PM | #10 |
Yea I got one a few yrs back, the seller had no idea what it was for and sold it for $5.00 Bucks. I paid him real fast. Iceman
