12-05-2020, 11:23 AM | #1 |
how to Remove Replace Rumble Seat Latch
I have a 30 Coupe with rumble seat and the rumble seat latch won't lock. I want to replace it, but I don't see how to get the locking latch handle out. Is this easy or do I have to take half the rear end off to replace the locking latch handle? Thanks
12-05-2020, 12:09 PM | #2 |
Re: how to Remove Replace Rumble Seat Latch
There should be a crown nut on the bottom of the handle shaft. Remove it and handle should pop out.
Can you post a picture. |
12-05-2020, 12:18 PM | #3 |
12-05-2020, 12:23 PM | #4 |
Is it maybe covered by the seat.
12-05-2020, 12:28 PM | #5 |
Maybe picture helps.
12-05-2020, 12:56 PM | #6 |
12-05-2020, 06:04 PM | #7 |
To my knowledge no cross bolt in the shaft BUT the lock has a slider piece in it that may have broken off.
12-05-2020, 06:05 PM | #8 |
Have you know way to send me a picture.
12-05-2020, 06:15 PM | #9 |
This is not your handle but if you look at yours this is what it should look like.
You can see the slider pin clearly. |
12-05-2020, 06:19 PM | #10 |
http://www.plucks329s.org/pdf/studie...%20PART_1A.pdf
This is an article on how to work on a rumble lid Check it out it may help you. |
12-05-2020, 06:34 PM | #11 |
Yeh...that slider pin is completely missing. I'll order a new handle and hope it fits. Maybe I should look down inside the metal metal lid and see if there's a pin in there. I'd like to keep the original handle and key if possible. Thanks to all for your help. Case closed.
12-06-2020, 10:44 AM | #12 |
The replacement handle is for door, trunk and rumble lid; the threaded shaft has to be cut to length. The one I got needed the threads chased to get the nut on. My latch had broken the same way as yours, and I could see no way to repair it.
The replacement latchbox needs to be painted to look original, but it can't be seen anyway. Last edited by Badpuppy; 12-07-2020 at 09:59 AM. |
12-08-2020, 12:48 AM | #13 | |
I use Dick Crabtree to do all my lock work. Excellent work at a very fairly price and fast turn around. Contact Dick at 605-487-7229 or [email protected] That is what I would do. Chris W. |
