07-23-2018, 08:58 AM | #1 |
oil pan appendage
Pulled out this oil pan to use in my new build and noticed this.
Thought it was a return line from an added filter,but upon inspection I found it is blind with no opening on the inside of the pan. Any idea what it is for ??? |
07-23-2018, 09:19 AM | #2 |
Re: oil pan appendage
Look on that blind spot on the bottom side and see if there is not a slot cut in it to direct oil flow towards the bottom of the pan.Spray some carb cleaner or WD-40 in the fitting and see if it comes through to the inside.
07-23-2018, 03:11 PM | #3 |
The return hole is located on the bottom of the appendage.
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
07-23-2018, 06:00 PM | #4 |
If it has no return hole, it may be a plug for a vehicle with no filter added. (return delete)
07-23-2018, 06:28 PM | #5 |
As has been indicated there should be a slot in the bottom which directs the oil flow toward the bottom of the oil pan.
07-23-2018, 06:41 PM | #6 |
07-25-2018, 10:00 PM | #7 |
Checked and found a small hole about 1/16 on the bottom.
07-26-2018, 08:27 AM | #8 |
1941 pans had a return fitting at that exact spot. I've had pans like yours and have wondered, like you, why the "patch" on the inside.
