07-10-2016, 03:33 PM | #1 |
Head gasket again
I wanted to buy a "BEST" brand head gasket but it seems that none of the big Model A part houses sell the "BEST" brand. "BEST doesn't sell retail so if it's so good, why isn't it avaible through the normal channels?
07-10-2016, 03:36 PM | #2 |
Re: Head gasket again
Ask the manufacturer who retails their product! Wayne
07-10-2016, 03:37 PM | #3 |
Go to Bests web site,they list the suppliers there.
Lawrie |
07-10-2016, 04:21 PM | #4 |
HI Divco1,
I have just bought BEST G509 from Arizona Model A and G573 from Steve Becker at Berts. 509 is for A head up to 4 inch bore and 573 is similar but with 2 small steam hole for B engines. It also fits A's and both work well with Snyders higher compression heads. Just ask for them by BEST part number as I don't think they are listed as BEST in the catalogues but I think Steves one is A 6051 B composition gasket.. These numbers are from memory as I don't have the gaskets or receipts with me at present. SAJ back in NZ |
07-10-2016, 04:25 PM | #5 |
The last "Best" head gasket I purchased was a B style from Snyders
07-10-2016, 04:44 PM | #6 |
http://secretsofspeed.com/gaskets.htm |
07-14-2016, 11:39 AM | #7 |
For Thomas Head from Snyders part number is B-6051-C it has 573 stamped on it, I had tried copper first, spoke to them and they recommended this one as it was thinner and would not require many re-torques. Note I had leak up head bolt between 1 and 2 when I pulled head there was nothing wrong with copper gasket. 250 miles on new rebuild. Diamond block.
07-14-2016, 08:58 PM | #8 |
Antique Engines in Skokie recommends Best 573 for their hi compression head engines which is available at ANTIQUE FORD on Long Island. 631 256 0030.
07-15-2016, 07:54 PM | #9 |
I buy my head gaskets from Brattons, spray them with Copper Coat, put a 2" piece of copper wire in the Copper Coat between #3 AND #4 for renforcement, and reinstall the head. Torque to 50#, run to operating temp and torque to 55#
07-15-2016, 08:26 PM | #10 |
I ordered the "best" gasket from Sandy Olson. My original question was why don't the big 3 or 4 model A suppliers sell the gasket that a lot of people recommend. Snyders sell the 573 but not the 509. Best doesn't recommend the 573 with a stock head.
07-15-2016, 10:40 PM | #11 | |
Best bet is to ask them to get the true answer.
07-15-2016, 11:26 PM | #12 |
they prolly have a mountain of FelPros on the shelf they need to move. The FelPros only fit the stock head well; they fit the HC heads very poorly
'31 180A |
07-15-2016, 11:50 PM | #13 |
What gasket would you guys recommend for a Model B police head on a Model A block?
Neil |
07-16-2016, 12:47 AM | #14 |
I trust the head manufacturer. The Brumfeld HC head calls out a R3 Felpro.
07-16-2016, 09:48 AM | #15 |
only the R4 avail now as far as i know
never had a Brumfield in my hand to examine the fit in the valve area. That is where some gaskets do not match up well
'31 180A |
