04-09-2016, 05:09 AM | #1 |
gear box oil
would there be a modern substitute oil for gear box available? seems here in Canada 600 weight is non existent , vendors will not ship to Canada.tried several tractor supply houses to no avail.
04-09-2016, 05:42 AM | #2 |
Re: gear box oil
600W is about a 250 weight. I've used 140 with no problems especially in cooler weather.
04-09-2016, 06:02 AM | #3 |
Re: gear box oil
Thanks Patrick, cool weather? we are just opposite waiting for our 2 weeks of summer with highs of 20 C..... first time for me with a Model A, always cold so something that sticks to and lubricates gear train is what i need , but be able to shift reasonably smooth, not like trying to mix concrete . i will check around and take a look into your suggestions.
04-09-2016, 06:45 AM | #4 |
Re: gear box oil
I have been using 80-140 for years. Before that just plane 90w. The sport coupe has 25,000 miles with 80-140w.
04-09-2016, 07:09 AM | #5 |
Re: gear box oil
i also live in Canada and I buy 600 at the TSC store. Also Carquest will order it in for you. Wayne
04-09-2016, 10:19 AM | #6 |
Re: gear box oil
what is called 600w now is steam cylinder oil---for steam and worm gears the 600 series of gear lubes---for spur and bevel gears is what you want, I have Shell Omola 680, but perhaps you want the next thinner because of your temps regular automotive gear oils will protect the gears----quite possible 140 weight could be good |
04-09-2016, 11:20 AM | #7 |
Re: gear box oil
If you read any old model a news the former tech adviser Rodger Coffmen use to suggested and always used straight STP . This must be available to you in Canada.
04-09-2016, 11:45 AM | #8 |
Re: gear box oil
Lubriplate Company is one supplier with many grades such as SPO288, etc. Try their website for distributors and products.
04-09-2016, 11:59 AM | #9 |
Re: gear box oil
Or try 1/2 STP and 1/2 lucas Oil Stabilyser. (sp) I don't like pure, 100% STP, but it works. This concoction shouldn't leak out. Is thick enough to slow the gears down for shifting. and has superior lubricating properties.
Terry |
04-09-2016, 01:00 PM | #10 |
Re: gear box oil
George in Edmonton has it. so does the fella in medicine hat alberta I just got some
04-09-2016, 01:04 PM | #11 |
Re: gear box oil
I use either Chevron 680 or Mobil 680 gear oil in both my transmission and differential. It is certainly heavy enough to slow the gears in the transmission when coming to a stop. It is also an excellent lubricant. Purchase a five gallon pail and you will be stocked with oil for years to come. You will most likely have to go to a wholesale supplier for this product.
04-09-2016, 02:12 PM | #12 |
Re: gear box oil
I use 1/2 Lucas oil stabilizer and 1/2 Lucas heavy duty gear oil.
04-09-2016, 04:55 PM | #13 |
Re: gear box oil
i thank you all for your expertise, i least i have some numbers to search out. thanks
04-09-2016, 06:18 PM | #14 |
Re: gear box oil
I get mine from George Moir, Stoney Plain, Alberta. Phone: 780-963-7334.
04-09-2016, 10:27 PM | #15 |
Re: gear box oil
This has been around the block a few times and the consensus includes
TEXACO Meropa 680, SHELL Omala 680, MOBILE Mobilgear 600 XP, and AMSOIL ISO 460 =SAE 139 |
04-10-2016, 12:41 AM | #16 | |
Re: gear box oil
