03-29-2016, 02:39 PM | #1 |
throw out bearing
new to Model A but willing to learn, got a issue with clutch /pressure plate and throwout bearing. i never had the experience of disassembly only the pleasure of reassembly, anyway the flywheel is mounted and clutch disc sandwiched between flywheel and pressure plate , aligned with tool ,all good. throw out bearing return spring replaced and new clutch disc. Gear box installed . Heres my problem . when depressing clutch peddle , bearing easily slides forward but doesn't come near fingers on plate and only with peddle completely depressed to its full travel does it just barely touch fingers. what is missing ?
03-29-2016, 02:50 PM | #2 |
Re: throw out bearing
Have you adjusted the free play in the pedal?
Bob |
03-29-2016, 04:38 PM | #3 |
thanks for reply Bob, i have engine and trans on a bench, with inspection cover off looking at throwout bearing if i travel clutch lever its full travel the bearing moves towards fingers but will not contact them after full travel . am i missing something ?
03-29-2016, 04:48 PM | #4 |
Have you adjusted the linkage from the pedal to the throw out bearing shaft? There is a threaded rod that goes between the two and adjusts the amount of travel.
03-29-2016, 04:54 PM | #5 |
Could it be you have a throw out bearing carrier from an AA truck?
They are quite a bit shorter... Can you post a picture? Here is a picture Bob C posted some time ago on a different thread...
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 Last edited by 1955cj5; 03-29-2016 at 05:17 PM. Reason: Picture |
03-29-2016, 05:01 PM | #6 |
03-29-2016, 05:06 PM | #7 |
throw out style body is the longer type
03-29-2016, 05:15 PM | #8 |
It's possible you have the disc in backward, if so it will compress the pressure plate moving the release arms inward.
Nothing can be made foolproof, ---- fools are ingenious bastards. |
03-29-2016, 05:31 PM | #9 |
thanks for suggestions, will try to post a picture , disc not in backwards ,it fit flush on flywheel and can see cushion springs while looking inside cover.
03-29-2016, 05:38 PM | #10 | |
Pictures will get you the information that you seek ! You do not say, but I'm wondering ...are you working on stock setup, i.e.-trans/pressure plate, etc....? |
03-29-2016, 07:30 PM | #11 |
The 6 fingers should be 11/16" in from the surface of the pressure plate. A simple tool to make is a 5" piece of aluminum channel with a 1/4" bolt and nuts in the center, so you can lay the channel across the face and slip a feeler gauge between each arm and the bolt head to make sure it's 11/16". It can be plus or minus 1/16" from the 11/16", but make sure all 6 fingers are exactly even.
03-29-2016, 08:08 PM | #12 |
Agree with Tom. Adjust the PP fingers. It is easy enough with the engine out. Lots of threads on this.
03-29-2016, 08:19 PM | #13 |
Here's a link to a thread showing the tool I just mentioned:
http://www.fordbarn.com/forum/showth...e+tools+clutch And here's a link to the electronic clutch adjust tool I made: http://www.fordbarn.com/forum/showth...e+tools+clutch |
03-30-2016, 05:13 AM | #14 |
thanks Tom , trying to get back at car to take a picture, but while looking into inspection cover shouldn't T O bearing be near fingers? mine appears to slide forward 3 or 4 inches before coming in contact with fingers , the bearing body is long style.
03-30-2016, 05:17 AM | #15 |
yes its all stock setup.
03-30-2016, 08:14 AM | #16 |
Yes, when the tranny is mounted in the car and the linkage connected, the throwout bearing will be very close to the 6 fingers. Until the linkage is connected the return spring will pull it back as far as it can move.
03-30-2016, 09:21 AM | #17 |
This is how my external linkage looks with approximately 1" of free travel in the pedal..
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 |
03-30-2016, 10:25 AM | #18 |
My guess is you have a sheared pin on either the fork that moves the throwout bearing or the leaver that is moved by the pedal. Grab both and see if one or the other moves on the shaft.
03-30-2016, 10:54 AM | #19 |
Times 2 something to check
03-30-2016, 05:03 PM | #20 |
guys i gotta say thank you, situation remedied, as suggested fingers on pressure plate off by a mile, i am using original p.plate, problem was i purchased a aftermarket clutch disc , it may be ok but way to thick , noticed while taking off p.plate that fingers came out and while reattaching the fingers were drawn in. gotta say a special thanks to Tom and his simple but effective adjustment tool and his words of wisdom. thanks again
