Old 12-24-2020, 11:34 AM   #1
STAN WHITE
Default 33 Dash instrument gage panel
I would like to know the thicknes of the engine turned gage panel on a 33 Dash as I have to make one. Thanks Stan
STAN WHITE is offline   Reply With Quote
Old 12-25-2020, 08:57 PM   #2
B-O-B
B-O-B's Avatar
Default Re: 33 Dash instrument gage panel
Stan, I made mine {from a street speed limit sign the county was replacing.
Make a set of(M-F) bucks from wood & lightly lube. Lay the aluminum on the female buck & male on top of the metal, set it in a 20 ton press go to work adding light pressure. When you get to the corners add heat & hammer gently to prevent stretching & cracking , cut out the gauge & speedo & polish. If engine turning do that before cutting the holes.
B-O-B is offline   Reply With Quote
Old 12-25-2020, 10:37 PM   #3
B-O-B
B-O-B's Avatar
Stan ,forgot to mention to J B Weld the studs on the back for mounting.
