Old 11-17-2020, 06:01 AM   #1
Wick
Wick's Avatar
Default Bent timing pin
Today I found a second bent timing pin. All the years of tuning A Fords and im surprised to find this twice in 6 months. I kept thinking distributor bushings,bent shaft, bad points cam.
Someone must have put a pry bar against the pin.
I've never heard of a pin being bent before. This is something else to write down in the old Book of secrets.
Wick
Wick is offline   Reply With Quote
Old 11-17-2020, 07:55 AM   #2
Patrick L.
Patrick L.'s Avatar
Default Re: Bent timing pin
Are you talking about the actual timing pin or the distributor locating pin ?
Its surprising either would be bent. But it just goes to show that people can do about anything when they put their mind to it.
Old 11-17-2020, 08:08 AM   #3
jb-ob
' Good Ol' Boy' NASCAR Model A Ford tuning secret.
jb-ob is offline   Reply With Quote
Old 11-17-2020, 08:24 AM   #4
Mike Peters
Mike Peters's Avatar
This must be what you are referring to? It sticks out of the timing cover when not in use and WOULD make a good thing to pry against for reasons we shudder to think about.
So when you tried to use the bent pin to time an engine, you could not get the timing right? Interesting.
Mike Peters is offline   Reply With Quote
Old 11-17-2020, 08:30 AM   #5
Jack Shaft
In the mechanic world "a good thing to pry against" is called a 'purchase'..
"get ya a purchase from that timing pin son"
Old 11-17-2020, 10:49 AM   #6
Patrick L.
Patrick L.'s Avatar
Well, I guess that would make sense. I type this as I shake my head. But, I've pried on things I shouldn't have.
Old 11-17-2020, 12:03 PM   #7
Wick
Wick's Avatar
Yep that's it. The removable timing cover pin.
Old 11-17-2020, 12:54 PM   #8
Bob Bidonde
Bob Bidonde's Avatar
Could it be that somebody actually tried to lift / hoist the engine by the timing pin? Or could it that somebody bent the pin to advance the timing? Or could it be that somebody banged the engine while it was out of the car?
Bob Bidonde
Old 11-17-2020, 01:12 PM   #9
30 Closed Cab PU
So let me know if I am off base here.
Seems to me the amount you would be off with a bent timing pin would very small. The only time it might make a difference is starting at full retard. Soon as the A is running you move the lever and being off that small amount is compensated.
I suppose you could set TDC with the Pin, put a stick/dowel rod in # 1 spark plug hole and hand crank to see how far off it is. Or some version of this method.
Old 11-17-2020, 02:20 PM   #10
Brentwood Bob
I might of bent one moving a motor around.
Don't recall.
Brentwood Bob is offline   Reply With Quote
Old 11-18-2020, 10:31 AM   #11
Dirtrack49
Dirtrack49's Avatar
I also have a bent timing pin in my engine. Have no idea why. Came that way when I bought the car.
I find it makes finding the hole in the timing gear a little difficult. Hard to get the pin to drop into the hole while cranking over the engine by hand. I usually just bring the number one cylinder up to TDC and take a look into where the pin is inserted to see if the gear hole is about to line up. Forgot to purchase a new timing pin on my last order.
I also would be curious as to why a timing pin would be bent?
Tom L.
Dirtrack49 is offline   Reply With Quote
Old 11-18-2020, 11:50 AM   #12
Gary Karr
Gary Karr's Avatar
My guess is that the timing pin was bent when someone was reinstalling the engine. They probably used a 2X4 to pry the engine into place, placing it down in the front crossmember and pushing against the front timing cover without first removing the pin.
Gary Karr is offline   Reply With Quote
Old 11-18-2020, 11:57 AM   #13
Jim Brierley
It was probably installed by Jack-the-bear, and he got a little rough with it???
Old 11-18-2020, 12:18 PM   #14
katy
katy's Avatar
One could try straightening it while it's in place.
