Old 07-24-2021, 02:29 PM   #1
Ken Arms
Ken Arms's Avatar
Default gas cap issue
Hi folks, so I have a Drake tank in my 34. The gas cap is original and I put a new cork (hand made) gasket on it, every time I fill up it leaks out, I'm careful to stop pumping too close to the top and the tank even has a flipper to trap the slosh. I tried an after market cap as well with no better luck. Help? Thanks Ken
Ken Arms is offline   Reply With Quote
Old 07-24-2021, 02:48 PM   #2
Lawson Cox
Lawson Cox's Avatar
Default Re: gas cap issue
Is it leaking out at the gas cap or is it leaking at the seam? Drake's tanks leak at the seam where the two pieces of the tank join each other. My 35 pickup tank leaks at the seam. I just don't fill it up over halfway.
Old 07-24-2021, 03:10 PM   #3
deuce lover
deuce lover's Avatar
Thicker gasket.My '33 did that and I found some thick oil impregnated cork gasket material.No more leaks.
Old 07-24-2021, 09:02 PM   #4
aussie merc
aussie merc's Avatar
try soaking the gasket in oil then pat of the excess
aussie merc is offline   Reply With Quote
Old 07-25-2021, 11:15 AM   #5
Ken Arms
Ken Arms's Avatar
Thanks, I will try the oil soak. Ken
Old 07-25-2021, 06:05 PM   #6
39portlander
39portlander's Avatar
Ken has that new gasket possibly caused some venting issues. I had a simillar problem with my 77 and the little vent hole was plugged with pollen/dirt ect.
As that tank might heat up in this July summer those vapors need a way out. Also check (if built in) the smaller 1/4-3/8 little neck overflow tube for blockage that also helps with venting.
39portlander is offline   Reply With Quote
Old 07-25-2021, 06:26 PM   #7
Rodrelic
There is always a series of stains around my hot rod tank cap, expected and accepted as constantly re-cutting the cork rings, don’t care anymore. Now it’s called patina, so save me work don’t care anymore
Rodrelic is offline   Reply With Quote
Old 07-25-2021, 06:46 PM   #8
Talkwrench
Talkwrench's Avatar
I still say mine uses loses more than it uses...
Old 07-26-2021, 10:52 AM   #9
Karl Wescott
Karl Wescott's Avatar
Some things to consider and check.
Do you have a vented cap? If so, its going to leak out the vent when the tank is full and gas sloshes or the car is at the wrong angle. Original 1934's had a non-vented cap, the vent was at the original fuel pickup/fuel gauge sender location. Before you switch to a non-vented cap make sure the tank is vented, Suction from a fuel pump has been known to collapse and crumple a tank.
Karl Wescott is offline   Reply With Quote
Old 07-26-2021, 11:52 AM   #10
deuce lover
Karl is correct.In fact 32-35 had a non vented cap.36-40 was vented.Here are pic of the back side of those caps.The left is 32-35 and right 36-40 that shows the vent hole.
Old 07-26-2021, 03:40 PM   #11
slowforty
slowforty's Avatar
I made a bib out of an old fender cover. Cut a hole for the fill tube and use the gas cap to hold it on. You can get creative with the shape
slowforty is offline   Reply With Quote
Old 07-27-2021, 04:52 AM   #12
1934
1934's Avatar
Ken, I had a lot of trouble with gas leaking from the cap on my '34. I tried everything; different caps, cork gaskets, rubber gaskets- nothing worked. Then I bought a cap from Tanks Inc. about 3 years ago and it hasn't leaked since!
Their # is; 877 596 3842. (Make sure you ask for a non-vented cap). Hope this helps. Good luck, Doug.
1934 is offline   Reply With Quote
