Old 01-21-2021, 09:26 PM   #1
Wehill99
Wehill99's Avatar
Default 1936 truck frame and bed mounting info wanted
Does anyone have the specifications for the cab and bed mounting bolts? I was hoping someone had the list to make one of many tasks easier.
Also, I ordered the rubber pads between the cab and bed. Anyone have a diagram to make sure they are correct and the right spot for each one?
Thanks
Wehill99 is offline   Reply With Quote
Old 01-21-2021, 10:39 PM   #2
Model51
Model51's Avatar
Default Re: 1936 truck frame and bed mounting info wanted
Are you looking for information related to a commercial pickup or the Ford Truck and stake bed? I can help with the truck but not the pickup.
Model51 is offline   Reply With Quote
Old 01-21-2021, 11:12 PM   #3
Wehill99
Wehill99's Avatar
Ford truck.
Old 01-22-2021, 08:09 AM   #4
Model51
Model51's Avatar
i can help you. In addition to the bolts and springs to mount the cab, you also need the set of wood blocks. If you send me a PM I can send you pictures and specifications.
Also, are you looking to mount the platform to the frame rails, or assemble the bed components or both?
Old 01-22-2021, 08:38 AM   #5
Model51
Model51's Avatar
See if this is what you are looking for.
