Old 02-15-2016, 08:26 AM   #1
Franchise_24
Franchise_24's Avatar
Question Throw Out Bearing
I am going to be replacing the throw out bearing on my 28 Leatherback. I am also going to get the new hub it goes on. Is there a trick or simple way to get the bearing on the hub, or would I need to take it somewhere to get it done?
Thanks!
1929 Model A Ford Coupe
Franchise_24 is offline   Reply With Quote
Old 02-15-2016, 08:32 AM   #2
Pinesdune
Pinesdune's Avatar
Default Re: Throw Out Bearing
It's best assembled with a hydraulic press, a nice steady pressure. You could rig something up to use a bench vise if you have one big enough.
Looking for the front bumper emblem that has "Ford, Made In Canada"
Pinesdune is offline   Reply With Quote
Old 02-15-2016, 08:48 AM   #3
Patrick L.
Patrick L.'s Avatar
A vise works just fine. It just needs to be pushed on squarely.
Old 02-15-2016, 09:55 AM   #4
Rancho Deluxe
Rancho Deluxe's Avatar
You say 1928, Does it still have the Multi Disc Clutch ?? If so, just remove snap ring, hold the bearing & tap collar it rides on with a brass drift and it will come of pretty easy..
Rancho Deluxe is offline   Reply With Quote
Old 02-15-2016, 10:52 AM   #5
Franchise_24
It's a late 28.
Old 02-15-2016, 11:09 AM   #6
CarlG
CarlG's Avatar
I had good luck with just freezing the bearing. It tapped in real nice.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 02-15-2016, 11:12 AM   #7
Tom Wesenberg
Tom Wesenberg's Avatar
The bearing is just a light press fit to the collar, so it should easily tap into place by using an oak board and hammer. Lightly tap side to side until the bearing is all the way down. As mentioned, a large vice or press will easily push the bearing into place.
You should tap on the inside of the bearing so you aren't hammering against the balls. I save an assortment of pipes and copper tubing for such jobs.
