Old 07-17-2014, 11:47 AM   #1
Franchise_24
Franchise_24's Avatar
Exclamation Pulling the head.
I need to take the head off on my Leatherback. I have everything taken apart, so is there a trick to getting the head lose to start to lift it off? I didn't want to get too rough with it, or hurt the engine block or anything. Thanks.
1929 Model A Ford Coupe
Franchise_24 is offline   Reply With Quote
Old 07-17-2014, 11:58 AM   #2
Purdy Swoft
Purdy Swoft's Avatar
Default Re: Pulling the head.
Try cranking the engine. Sometimes compression helps.
Old 07-17-2014, 12:19 PM   #3
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
There was a long, recent, discussion about this.
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 07-17-2014, 01:47 PM   #4
[email protected]
modela@aol.com's Avatar
You are going to trash this head gasket anyway so time to get friendly with PB Blaster on the studs, your putty knives, and a big hammer. If you are careful you will not scratch the block surface. Don't go in deep enough to hit any valves and go around and around the edge of the head with the putty knives. If it is still stuck and stubborn, then you can go up in size to screwdrivers, wooden wedges, etc. .
modela@aol.com is offline   Reply With Quote
Old 07-17-2014, 01:54 PM   #5
CarlG
CarlG's Avatar
Bill Stipe makes this handy dandy head puller that is available from most parts vendors as well. It works like a charm.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 07-17-2014, 04:29 PM   #6
rocket1
I can tell you this,if the head is stuck fast it will support the complete weight of the front of the car without budging,I just went through this! I had eye hooks in 2 sparkplug holes.
rocket1 is offline   Reply With Quote
Old 07-17-2014, 09:04 PM   #7
Franchise_24
Got it off. Some pry bars helped. Thanks!
Old 07-17-2014, 11:08 PM   #8
Mike V. Florida
Mike V. Florida's Avatar
"hang it" by the head and soak the studs. you can dam around the studs to hold more fluid. Use wooden shims and drive them into the gasket as well.
Old 07-17-2014, 11:19 PM   #9
700rpm
700rpm's Avatar
Be careful prying with anything. You can damage your block and head.
Ray Horton, Portland, OR
Old 07-18-2014, 01:07 PM   #10
Jdubwikk
Jdubwikk's Avatar
I have found that if you loosen the head bolts about two threads and hit the starter with the spark plugs installed the head will "pop" up and be a piece of cake to remove. This is actually a tip in Les Andrews book and it works like a champ. Good luck.
Jdubwikk is offline   Reply With Quote
Old 07-18-2014, 02:21 PM   #11
Franchise_24
Took the head to the machine shop and it has a crack in it by the water inlet area. You don't really fix something like that do you? Just replace it?
Old 07-18-2014, 02:31 PM   #12
Tom Wesenberg
Tom Wesenberg's Avatar
Good time to install the Snyder's 5.5 head.
I wouldn't try to weld a stock head.
Old 07-18-2014, 02:33 PM   #13
Franchise_24
That's what I figured too. Thanks Tom. What do you notice different on the 5.5 head compared to a stock head?
Old 07-18-2014, 02:55 PM   #14
Tom Wesenberg
I'm still using the stock head, but picked up a 5.5 head from Bert's in Denver when I stopped there. The 5.5 head should give a noticable improvement in horsepower, and it should run more efficiently, so you get better fuel economy and lower operating temp.
Old 07-18-2014, 07:06 PM   #15
Synchro909
Synchro909's Avatar
I'm with Tom. You will mostly notice better pulling power at lower RPM which makes the car more pleasant to drive. Yes, even more grunt - the Model A is notorious for having lots but this head will give you more and is just about a "must have" if you run an overdrive.
Old 07-19-2014, 07:17 AM   #16
Bob Bidonde
Bob Bidonde's Avatar
I have tried running engines with head nuts off, and not once did this ever loosen a stuck cylinder head.
Bob Bidonde
Old 07-19-2014, 08:45 AM   #17
Tom Wesenberg
The same for me.
Old 07-19-2014, 11:54 AM   #18
Purdy Swoft
Sometimes it helps,sometimes it doesn't. It would be my first try before driving wedges and running the risk of breaking something.
