08-25-2021, 11:22 AM | #1 |
Low compression, all holes
A bit of background. I'm seeing lot of blowback through the carb from idle to about 3/4 throttle. It blows air/fuel mixture back out the carb until the engine revs really climb, then it pulls it all in. It's bad enough that it won't go beyond idle with the air filter installed. All that fuel mist builds up in the filter and just chokes it out.
So I went and bought a new compression tester and my readings on all 4 pots are in the 32-35 psi range. Obviously low but consistent across all cylinders. My initial thought is a failing head gasket. It starts and idles nice and drives reasonable with the air filter off. Maybe sticking valves, but across the board? Seems too odd for that IMO. Any thoughts? |
08-25-2021, 11:27 AM | #2 |
Re: Low compression, all holes
Is this a new car, where it's been doing this as long as you've had it, or a car you've had for a while that just started doing this?
08-25-2021, 11:30 AM | #3 |
Car is new to me. I acquired it recently from an estate. Was not running when I got it. I'm unsure how long it's been parked
08-25-2021, 11:32 AM | #4 |
I have some ATF soaking in the cylinders right now.
08-25-2021, 11:39 AM | #5 |
That should produce lots of white smoke next time you start it.
08-25-2021, 11:43 AM | #6 |
08-25-2021, 11:45 AM | #7 |
Blowing FAM back through the intake manifold suggests that the intake valves are not closing at the end of the intake stroke (because of sticking, bad springs, bad cam, who knows what else).
08-25-2021, 12:17 PM | #8 |
Might be a good idea to check the lifter adjustment.
08-25-2021, 12:25 PM | #9 |
IMHO, Put some MMO in each cylinder and in in the gas, also, maybe some SeaFoam, drive it awhile, see if the sticky valves loosen up. Worth a try before tearing into the engine.
IN GOD WE TRUST - SEMPER FIDELIS John |
08-25-2021, 12:31 PM | #10 | |
Bill |
08-25-2021, 12:33 PM | #11 |
Good Morning...The Model A carburetor was not designed to be used with an air filter. The amount of extra sucking the engine must due to get fuel causes it to run rich...too much fuel and not enough air...I just use a small piece of screen door mesh over the inlet of my 'B' carburetor. If you are using old gas that came with the car...drain it out and put in fresh...old gas can really mess with your valve guides and make the valves stick...change the oil in the engine and transmission. Lube all 31 zerk fittings, check to make sure the rear end is full. Clean the plugs and gap them. Clean the points and make sure they are set properly. Check the head torque...55 pounds feet is enough... Perhaps a new condenser and coil...run her around at slow cruising speed 30-35 for a 100 or so miles and I think she will surprise you...Ernie in Arizona
08-25-2021, 12:33 PM | #12 | |
Bill Last edited by bbrocksr; 08-25-2021 at 12:34 PM. Reason: duplicate post |
08-25-2021, 12:40 PM | #13 |
I will try and check all of the above before I tear into it. Thanks everyone.
Is the valve cover/plate as easy to remove for inspection as it appears? Seems straightforward. |
08-25-2021, 12:45 PM | #14 | |
JayJay
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan |
08-25-2021, 12:51 PM | #15 |
In 1937 a mechanic would tell you that it is time for a valve and ring job.
08-25-2021, 12:53 PM | #16 |
The thing that jumps out at me is the consistent low readings. If you have ATF in the cylinders then you could repeat the compression test with the cylinders wet. A consistent increase with wet cylinders would tend to indicate worn rings (you might need something a bit heavier like 30wt oil, several squirts before the compression test). I don't see head gasket with the consistent low readings you're seeing, more like ring wear. If it was valves you will not see much increase in compression, but that backfire does point in that direction. No reason it could not be both rings and valves - a just plain worn out engine.
I agree that an air filter, especially one clogged with backfire crud, doesn't help. JayJay
08-25-2021, 02:01 PM | #17 |
Checking the obvious first, were the plugs out and throttle fully open when checking compression? Timing checked and checked again. Since it drives "reasonable" with the filter off, not sure what more you want. Filter is marginal use anyway. If the compression numbers are accurate it just seems the engine is tired.
08-25-2021, 02:50 PM | #18 |
Drive it for awhile. Adding some oil to each cylinder and letting it set for awhile is good.
Mine has had 45# compression for 45 years and runs fine. |
08-25-2021, 02:54 PM | #19 |
Was the throttle wide open when to took the compression readings??
08-25-2021, 04:02 PM | #20 |
A couple of more things to check, probably not the cause of low compression but good to check with an A that's be sitting! Oil fill cap clogged or on to far, and that the muffler is not clogged by Mr & Mrs mouse !
