Old 08-05-2019, 07:15 PM   #1
JimNNN
Default Lubrication for Y block water pump shaft (?)
What is that hole in the water pump of my '54 y block? It's about 1/8" in diameter, is at the top of the pump and exposes the inner shaft. It looks like a lubrication port of some type for the shaft, but the shop manual doesn't seem to mention anything about putting lubricant in it. Thanks
JimNNN is offline   Reply With Quote
Old 08-05-2019, 07:18 PM   #2
KULTULZ
KULTULZ's Avatar
Post Re: Lubrication for Y block water pump shaft (?)
It is a coolant seepage hole that alerts you to a bad WP seal.
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 08-05-2019, 07:40 PM   #3
JimNNN
Default Re: Lubrication for Y block water pump shaft (?)
Thanks again, Kultulz!
Old 08-05-2019, 10:32 PM   #4
Daves55Sedan
Daves55Sedan's Avatar
DO NOT squirt oil down the 1/8 inch diameter hole in the water pump shaft neck casting. If you do, you will be replacing your water pump in less than a week. That hole is only there to allow water to exit when the pump seal goes bad (letting you know that you need to rebuild the pump or get a new one).
Daves55Sedan is offline   Reply With Quote
Old 08-06-2019, 12:39 AM   #5
JimNNN
That's why I asked. Thanks Dave.
