Old 09-25-2013, 08:54 AM   #1
RonC
RonC's Avatar
Default Briggs Stratton Key Code for A1060
Does any have the key code for a Briggs and Stratton A1060 replacement ignition switch? I need a key made from a local locksmtih
Thanks
RonC is offline   Reply With Quote
Old 09-25-2013, 11:16 AM   #2
Rowdy
Default Re: Briggs Stratton Key Code for A1060
Personnaly I think you are further ahead to order a replacement key from A&L. Key codes will differ depending on the machine the place that is cutting them has. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 09-25-2013, 01:40 PM   #3
Mike V. Florida
Mike V. Florida's Avatar
The actual codes are the same. The codes are the codes. If any key cutting machine is calibrated it will cut the same as any other calibrated machine.
Old 09-25-2013, 01:50 PM   #4
Ron in Quincy
Ron in Quincy's Avatar
The key code for A1060 is : 15553
Ron
Ron in Quincy is offline   Reply With Quote
Old 09-25-2013, 02:34 PM   #5
RonC
RonC's Avatar
many thanks Ron!
