Old 09-13-2021, 11:49 AM   #1
kursed30
kursed30's Avatar
Default A few timing gear questions
So the other day I finally got the large timing gear off. Got the new aluminum one on yesterday and managed to get the two lines matched up after some cuss words. Before I close it up is there anything I should check first? Do I need to add any grease to the gears? I have new cork gaskets for the inspection plate and the front cover of the gears. Do cork ones need any gasket sealer put on?
kursed30 is offline   Reply With Quote
Old 09-13-2021, 12:04 PM   #2
Aretino
Aretino's Avatar
Default Re: A few timing gear questions
Spring loaded plunger well greased
Aretino is offline   Reply With Quote
Old 09-13-2021, 01:02 PM   #3
PC/SR
Double check the crankshaft lineup is correct. Put a bit of grease across the gears, assemblyi lube is better but any will do.
PC/SR is offline   Reply With Quote
Old 09-13-2021, 02:44 PM   #4
Patrick L.
Patrick L.'s Avatar
Oil the gears after double and triple checking them. Make sure the nut is TITE.
Grease the plunger and spring. I usually shim the spring if reusing the old one.
Sealer on the gaskets is OK. A little goes along way.
If the rope seal is being replaced, do not cut it, oil it, do not grease it.
Old 09-13-2021, 02:51 PM   #5
Rob Doe
I suggest you take a picture of the gear alignment and post it here before closing things up.
"It ain't what you know for certain that gets ya in trouble. It's what ya know for certain that just ain't so!"
Rob Doe is offline   Reply With Quote
Old 09-13-2021, 03:07 PM   #6
chrs1961815
chrs1961815's Avatar
Tighten the nut down well with the special tool then drive it home with a hammer and chisel a few times.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 09-13-2021, 03:39 PM   #7
kursed30
kursed30's Avatar
Here is a picture I took. I didn't see any markings on the crankshaft gear but a few places I read mentioned the key slot works also.
Old 09-13-2021, 04:02 PM   #8
LeonardS
I just checked an extra crankshaft I have. It has a mark on 2 teeth that are side by side, one each side of the key way. The marked tooth to the right of my key way also has a “0” marked on the front of the tooth.
LeonardS is offline   Reply With Quote
Old 09-13-2021, 04:05 PM   #9
chrs1961815
No you look good.
Old 09-13-2021, 04:06 PM   #10
Ruth
Is that a timing mark on that tooth. I think you may be off.
Ruth
Old 09-13-2021, 04:11 PM   #11
chrs1961815
Upon second look, I can't tell where the crank mark is for sure.
Old 09-13-2021, 04:13 PM   #12
LeonardS
I agree Ruth.
Old 09-13-2021, 04:19 PM   #13
Ruth
I think the keyway should be to the left (in your picture) of the cam gear mark.
Ruth
Old 09-13-2021, 04:47 PM   #14
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Yes , the key way is to the left. You’re one tooth off.
Old 09-13-2021, 04:58 PM   #15
WeldonS
WeldonS's Avatar
Just changed my timing gear and it appears you are off one tooth. The marked crankshaft tooth is to the right of the keyway.
WeldonS is offline   Reply With Quote
Old 09-13-2021, 05:06 PM   #16
Patrick L.
Patrick L.'s Avatar
Try to take a really good at the crank gear for the mark, it should be there. That'll let you know for sure.
I think the fellas are right, it does look from what we can see that you are off a tooth.
Old 09-13-2021, 07:46 PM   #17
kursed30
kursed30's Avatar
So what does being off one tooth do exactly?
Old 09-13-2021, 07:59 PM   #18
kursed30
kursed30's Avatar
another pic
Old 09-13-2021, 08:01 PM   #19
chrs1961815
Still hard to tell where that mark is. Being a tooth off will throw the timing off.
Old 09-13-2021, 08:04 PM   #20
kursed30
kursed30's Avatar
I put the plate back on and and when I turned the engine over until the pin hit the dot. I took out the spark plug and it was TDC.???
