Old 07-28-2019, 01:00 PM   #1
jw hash
jw hash's Avatar
Default ford overdrive
is anyone making a kit to install the F150 overdrive transmission in a Model A I would like to install one in the 68B that I`m putting together.
jw hash is offline   Reply With Quote
Old 07-28-2019, 02:15 PM   #2
old31
Default Re: ford overdrive
Dave Delmue
Morgan Hill CA
[email protected]
406 722 2518
OR
408 930 4502
Old 07-29-2019, 07:31 AM   #3
Dave in MN
Dave in MN's Avatar
If you want a T-5 and don't mind an open driveshaft....
John Baker
Transmission Exchange
Monticello, KY
[email protected]
606-348-8533
I have installed one of his systems in my touring car and am well satisfied with it.
Good Day!
Dave in MN is offline   Reply With Quote
Old 07-29-2019, 10:53 AM   #4
Jim Brierley
I would go for the Chevy T-5 because of the gear ratios. The F-150 has a nice split between 1st and 2nd, and 3rd and 4th but the 2-3 shift is huge.
Jim Brierley is offline   Reply With Quote
Old 07-29-2019, 01:18 PM   #5
CarlG
CarlG's Avatar
The 2-3 shift is essentially the same as a Model A transmission, isn't it?
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 07-29-2019, 07:05 PM   #6
jw hash
jw hash's Avatar
Thanks everyone. I want to go with the ford set up because I want to keep the closed drive shaft.
Old 07-29-2019, 07:23 PM   #7
Pmsqrd
Pmsqrd's Avatar
You will not be disappointed. My Ranger 4 sped works great. Copy on the closed drive line.
Pmsqrd is offline   Reply With Quote
Old 07-29-2019, 10:20 PM   #8
Chris Haynes
Chris Haynes's Avatar
Modification of the cross member is necessary for this swap.
1921 Runabout
1930 Tudor
Early 1930 AA
Speed costs money. How fast do you want to go?
Chris Haynes is offline   Reply With Quote
Old 07-29-2019, 10:42 PM   #9
BillLee/Chandler, TX
BillLee/Chandler, TX's Avatar
Not necessarily so.
Bill Lee
http://www.CedarCreekAs.org
BillLee/Chandler, TX is offline   Reply With Quote
Old 07-29-2019, 11:03 PM   #10
c. sefton
Tim Sheridan, Nunica Michigan. Do a search on him.
C1-C2
c. sefton is offline   Reply With Quote
Old 07-29-2019, 11:47 PM   #11
CarlG
CarlG's Avatar
Using Dave’s kit there’s no cutting or drilling except the wood floor board. It’s a complete bolt on kit.
Alaskan A's
Old 07-30-2019, 01:54 AM   #12
old31
x2 with Carl.
Daves kit is a first-class fit and goes in easy. For those of you that want to stay with the original look with no cutting, this is the kit.
Because the gear shift is moved about 1-1/2 inches towards the rear, the floor board hole must be moved. If you have carpets them you need a new carpet.
The only thing I wish this kit had is a 5th gear.
Old 07-30-2019, 06:39 AM   #13
brokenspoke
I used a S10 4x4 5 speed and kept the torque tube
brokenspoke is offline   Reply With Quote
Old 07-30-2019, 10:59 AM   #14
Jim Brierley
CarlG, yes that split is about the same as Model A. Steve Serr of Miller hi-speed makes a closed drive line adapter for the T-5.
