Old 08-26-2018, 08:05 AM   #1
1929
Default Months of confusion
The car would run good, then the next day there would be problems, it was a pattern like this all the time. I almost removed everything to go back to stock. Cleaned the carb, even put another carb on, no difference. Removed the FS ignition, went back to stock. Drained some fuel, no debris, and installed a new fuel line. Removed fuel pump and regulator, went back to gravity, still same results. Installed new dashboard wires,new plugs etc,etc. Had others look and try to figure it out, they were confused, until one guy said, take off the GAS CAP, which was only over 3 years old. Now the car runs great again. All this could have been avoided by just five seconds of unscrewing a GAS CAP! The inner part of the gas cap with the hole looks like it went flat to the top surface, wondering if that's where it started, or if the fuel pump created the issue to the cap.
1929 is offline   Reply With Quote
Old 08-26-2018, 08:30 AM   #2
Jim/GA
Jim/GA's Avatar
Lightbulb Re: Months of confusion
That's a very valuable lesson to learn. Thanks for sharing with us!
I had a similar experience a few years ago while on tour. One of the cars touring with us had a problem with his car running poorly at times, and it ran great other times. We were driving a lot each day and refueling pretty often. He pulled over once right after refueling at an Exxon station and he was out of his car, ranting and raving about how that Exxon gas was bad, causing the problem. Everyone else's car was running fine on it.
One of the guys in the group reached out and loosened the gas cap 1/4 turn (it was a'31 S/W Town Sedan) and said "Let's try this for a few miles". Sure enough, the car ran great for the rest of the tour if he left the gas cap loose (days of driving). When the tank was full, there was not much air in the top of the tank to expand as the gas was consumed. So the fuel would not flow to the carburetor.
Jim Cannon
Former MAFCA Technical Director
"Have a Model A day!"
Jim/GA is offline   Reply With Quote
Old 08-26-2018, 10:17 AM   #3
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Default Re: Months of confusion
This reminded me, many times when attacking a problem such as this, the filter in the top of a Zenith, is often overlooked!
Bill Pluggedup
"THE ASSISTANT GURU OF STUFF"
Old 08-26-2018, 11:28 AM   #4
johnbuckley
johnbuckley's Avatar
you got off lightly 1929.... I took the head off once trying to trace a running fault -- should've just taken the gas cap off!!
johnbuckley is offline   Reply With Quote
Old 08-26-2018, 01:35 PM   #5
Tom Endy
Tom Endy's Avatar
The reproduction gas caps for the 30-31 cars are designed to fail with the single rivet in the center. Repeated twisting of the cap on and off the tank will eventually allow one of more of the three parts to rotate out of position and block off the vent hole.
Snyder's carry a better reproduction cap with two rivets.
Attached article shows how to modify the single rivet caps before they cause grief.
Tom Endy
Tom Endy is offline   Reply With Quote
Old 08-26-2018, 01:36 PM   #6
john in illinois
john in illinois's Avatar
The gas cap vent was the first problem I had with my new to me A 10 years ago.
We made it about 3 miles from home on our first ride.
Good luck.
John
john in illinois is offline   Reply With Quote
