Old 04-07-2013, 10:48 AM   #1
kippmw
kippmw's Avatar
Default Brake light wiring
Hey everyone,
I am trying to figure out why one brake light would be very bright, as it should be and the other light is very dim, only barely lighting the filament. Any thoughts?
kippmw is offline   Reply With Quote
Old 04-07-2013, 10:52 AM   #2
larryf
Default Re: Brake light wiring
Check your ground
larryf is offline   Reply With Quote
Old 04-07-2013, 11:22 AM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
I agree with Larry, that it sounds like a poor ground. Take a jumper wire and touch the housing to a good ground. If no change, then remove the lens and touch the light socket body to a good ground.
Old 04-07-2013, 12:42 PM   #4
Jim Brierley
Tail lights are grounded through the fender, the frame, etc. Many points to check.
Jim Brierley is offline   Reply With Quote
Old 04-07-2013, 03:08 PM   #5
Brentwood Bob
Try my trick for cleaning the barrel of the socket for each light. When you disassemble the tail lite assembly, use a plumbers pipe fitting wire brush to brighten the light socket after you remove the wire/pig tail. Also clean the threads of the mounting screws on the back of the tail light assembly. Bob
Brentwood Bob is offline   Reply With Quote
Old 04-08-2013, 11:50 AM   #6
kippmw
kippmw's Avatar
Thanks for all the ideas. I tried using a jumper to ground the body and the socket and it didn't really make any difference. The sockets look clean and I pulled the light body off of the bracket and used some sandpaper to ensure a good ground. Still no difference. I wonder if there isn't sufficient voltage getting to the light... Bear with me, electrical isn't really my thing. Would the problem be where the wire splits from the other brake light? The driver's side is very bright...
Old 04-08-2013, 12:00 PM   #7
Bob C
Is the bulb the right voltage, try swapping the bulbs and see what happens.
Bob
Old 04-08-2013, 12:27 PM   #8
jrelliott
jrelliott's Avatar
Check the voltage. It should be about 6.2 V for 6V system and 12.4 for 12V system. If it is lower than that check the wiring from the driver's side to the passenger side especially the bullet connections. Solder them instead of crimping as makes a better electrical connection. You should also make sure the wiring is not a jury rig and using very small electrical wire instead of the proper size.
Bulbs are 1156 for 12V and 1133 for 6V 32 candle power or 1141 for 12V or 1129 for 6V 21 candle power for the Stop light.
jrelliott is offline   Reply With Quote
Thread Tools
Display Modes
