04-02-2021, 02:26 PM | #1 |
No Spark
This week I changed out my steering gearbox to the Ford F-100 truck gearbox. Went to start car and now no spark. I'm sure the gearbox change had nothing to do with the no spark issue. Just wanted tell what has been done to car recently. Prior to steering change it has not run in a couple of years. Got a new battery, gas is fresh, no trash in tank. Went to start and no spark at the plugs. I have 12 volts on both sides of amp meter, no voltage at switch ( I am using a keyed on/off switch not a pop-out). No voltage to either side of coil. All lights are working.
What am I missing?? Thanks for the help Todd |
04-02-2021, 03:26 PM | #2 |
Re: No Spark
You need power at both posts in the terminal box. Easy to track down. Check you fuse.
If you have power at ammeter, you must have it into and out of the term box. |
04-02-2021, 04:12 PM | #3 |
Re: No Spark
Forgot to mention that earlier. Fuse is good and I have 12 volts in and out of terminal box.
Also I am using an FS distributor. No points. |
04-02-2021, 04:36 PM | #4 |
Re: No Spark
Things about Electronic (FSI) Ignitions
1. If you leave the key ON for 30 seconds without engine running, the module will burn up. 2. The installation REQUIRES a continuous ground wire to be run back to the battery post - no "short cuts". 3. Reversing polarity of battery will burn out either a 6 or 12 volt module. 4. Hooking 12 volts to a 6 volt module will burn it out. 5 If engine is running and you remove a wire from a spark plug AND the spark inside the distributor happens to jump to the module it can be burned up. Last edited by Benson; 04-02-2021 at 04:42 PM. |
04-02-2021, 05:33 PM | #5 |
Re: No Spark
Do you have or can you borrow a known good mechanical distributor? They are easier to trouble shoot.
04-02-2021, 06:43 PM | #6 |
Re: No Spark
Like Benson says above, if you leave the ign on without starting the car you can burn up the module. It the car still work start your only choice is put a stock point style distributor in (and re do the wiring) or install another module. I suggest getting another module. Good Luck |
04-03-2021, 11:28 AM | #7 |
Re: No Spark
As Herb stated "There should be a fuse, between the battery post and the switch, check it if you don't have power to the ign switch."
Herein lies the problem. Somehow or another the fuse was removed and not put back in place. So no power to switch. Installed fuse and she fired right up. I love the simple fixes. Thanks to all who replied. |
04-03-2021, 11:35 AM | #8 |
Re: No Spark
Thanks to you for the followup.
04-03-2021, 05:19 PM | #9 | |
No Spark
I’m glad you found it. Sometimes, the simple things are tough to find. A while back, I had the distributor apart and reassembled without the rotor. From outward appearances, everything seemed in place, but no spark. Duh....... Sent from my iPhone using Tapatalk Last edited by shew01; 04-03-2021 at 06:48 PM. |
