Old 03-11-2021, 08:28 AM   #1
Oldford59
Default Radiator using water verse antifreeze
Hi,
I have been reading that putting antifreeze in a model a radiator is not recommended Just use water because original radiators are not pressurized.
My question is storing water in system over winter storage is there a chance of water freezing and expansion damaging engine block.
Should you drain system before winter sets in knowing model a will rest till spring.
Oldford59 is offline   Reply With Quote
Old 03-11-2021, 08:32 AM   #2
alexiskai
alexiskai's Avatar
Default Re: Radiator using water verse antifreeze
It’s like Groundhog Day around here.
(This got asked about a week ago.)
Old 03-11-2021, 08:32 AM   #3
Jack Shaft
The reason I use antifreeze is the corrosion inhibiting factor..Ford grey iron castings look stout but are actually pretty delicate.
Old 03-11-2021, 09:43 AM   #4
WHN
I have never used anti-freeze. Just water with rust inhibitor.
Now I drain radiator and put car away in fall before there is a freeze. We get it out again in the spring once the weather warms up. I have been doing the same thing for over 40 years.
In the fall before draining radiator, I run the carburetor dry. Take fuse out, and than cover the car. I check the car every few weeks for mice, and charge the battery for 1/2 hour.
That’s it. Works for me. DON’T leave any water in your radiator if it is going to get even close to freezing. Clacked block or head or both.
Old 03-11-2021, 10:56 AM   #5
Ernie Vitucci
Good Morning...Opinions vary...I use 50/50 mix for the rust factor have for the last 16 years with the same 31 Tudor...I live in the Desert and drive the car all year...admittedly early in the morning during the summer...early breakfast only! Other A's run with water have had problems...50/50 is a bit safer...lack of pressure radiator is not a factor. Ernie in Arizona
Old 03-11-2021, 11:19 AM   #6
1928Mik
1928Mik's Avatar
I use the 50/50 mix for the rust factor and to raise the boiling point.
1928 Niagara Blue Phaeton
1972 Olds 442 Convertible
1979 MGB
-Life's Too Short To Drive Boring Cars-
1928Mik is offline   Reply With Quote
Old 03-11-2021, 12:33 PM   #7
Mister Moose
Mister Moose's Avatar
This was discussed at length, but I'll summarize what I see as key facts to be aware of:
Running water only carries a freezing risk of you're in a freezing climate. If you forget to drain it when needed, you could crack the block.
Ethylene glycol (The green stuff) has LESS heat capacity than water. This means the rate of heat transfer per unit volume of coolant is less. This may not be a factor at all if your car never operates in temperatures where the radiator cannot conduct enough heat away faster than the engine is producing heat.
Scaling in the radiator, clogged tubes, poor fan blades, loose fan belt, poor water flow, and corrosion/debris in the block all inhibit cooling, and all our cars are different.
Automotive antifreeze includes anti-corrosion protection - iron rusts. Yet normal operation when new was water in above freezing temps.
Ethylene Glycol raises the boiling point.
Propylene Glycol is available, is more environmentally friendly, and costs more.
I have some kind of cooling issue, or baffle/overflow problem, as the radiator burps out water until I get quite warm going up hills. Until I get that figured out, I'm running water as I go through so much. Once addressed, Id go to a 45/55 mix. I don't drive in the winter, from 1st application of road salt to when all salt is washed off in April.
Mister Moose is offline   Reply With Quote
Old 03-11-2021, 02:14 PM   #8
Kurt in NJ
Kurt in NJ's Avatar
One picture-- always antifreeze, other pic water for some of its life---
Old 03-11-2021, 03:43 PM   #9
redmodelt
redmodelt's Avatar
If you like rust use straight water! Even my 1948 truck owners manual warns against just using water. They say to use the anti rust/corrosion protection/water pump lube if you don't use anti-freeze. While the water is out, rust happens in that moist environment.
Old 03-11-2021, 07:36 PM   #10
Dave in MN
Dave in MN's Avatar
Originally Posted by Oldford59 View Post
Hi,
I suggest you use 50/50 water antifreeze. I fix or replace about one motor or head each year because someone forgot to drain the water from their system.
I have heard all kinds of stories as to how or why it happened. Every story filters down to a human mistake. (See post #17)
I live in Minnesota and I use a 50/50 mix in all my vehicles.
Good Day!
Dave in MN is offline   Reply With Quote
Old 03-11-2021, 07:51 PM   #11
RRW
Send a message via Yahoo to RRW
I have used Red Line Water Wetter since 2001 with no problems and 'it' stays quite clear. I switch 'it' once a year.
However, I live in Bullhead City, AZ which reaches 126 degrees in the summer.
RRW is offline   Reply With Quote
Old 03-11-2021, 09:26 PM   #12
johnneilson
Originally Posted by 1928Mik View Post
I use the 50/50 mix for the rust factor and to lower the boiling point.
I sure hope you mean to raise the boiling point!!
J
As Carroll Smith wrote; All Failures are Human in Origin.
johnneilson is offline   Reply With Quote
Old 03-11-2021, 10:43 PM   #13
Oldford59
Thanks for taking the time to respond
Much appreciated!
Old 03-11-2021, 10:51 PM   #14
daren007
Use antifreeze and forget it. Why make life more complicated.
daren007 is offline   Reply With Quote
Old 03-11-2021, 11:08 PM   #15
CWPASADENA
CWPASADENA's Avatar
The reason we would not run permanent anti freeze in the old days was if the head gasket leaked a little, you could get antifreeze in the oil and the Babbitt bearings did not like ethylene glycol.
We would run temporary antifreeze which basically was alcohol but that would evaporate by summer and we were down to pure water so we would add rust inhibitor or water soluble oil to keep the corrosion in check.
Todays head gaskets and hardened head studs are better at keeping the head sealed so antifreeze can be used with more confidence that it will not get into the bearings.
Chris W.
CWPASADENA is offline   Reply With Quote
Old 03-12-2021, 12:22 AM   #16
old31
A 50/50 mix will be much better for your engine that just straight water.
When you do a 50/50 mix do not use tap water only distilled water. Your radiator likes not having to digest the minerals in water.
old31 is offline   Reply With Quote
Old 03-12-2021, 06:57 AM   #17
Jacksonlll
Jacksonlll's Avatar
We are all getting older. Don't hang your hat on draining the water out every winter. You forget, just once, and you have big problems. This forgetting business has been the end of many old timer's engines.
Old 03-12-2021, 08:29 AM   #18
Oldford59
Thanks to all the old timers keeping their Model A’s rolling down the road!
Old 03-12-2021, 11:12 AM   #19
katy
katy's Avatar
True, but it happens to youngsters also.
