08-03-2010, 05:40 PM | #1 |
36 window
gentelman
i need some advice on r&r for the door glass, and regulator , on my 36 coupe .this one has me stumped,!!!!!!!!!! cant get the regulator out of the door ??? thanks jonny |
08-03-2010, 06:37 PM | #2 |
Re: 36 window
I replaced my windows a number of years ago in my 35 FORDOR Sedan and recorded everything I could think of in a word file.
If you wish I will send it as an email attachment as I tried but was not able to on the forum. |
08-03-2010, 07:17 PM | #3 |
Re: 36 window
Admiral , I would love that also /
Thanks cheers tony |
08-03-2010, 08:27 PM | #4 |
Re: 36 window
08-04-2010, 05:25 AM | #5 |
Re: 36 window
i'm also changing a regulator and side glass. please forward that info to me also. thank you very much!!! [email protected]
08-04-2010, 07:35 AM | #6 |
Re: 36 window
08-11-2010, 11:15 PM | #7 |
Re: 36 window
Please send me a copy also. [email protected] Thanks
08-12-2010, 04:07 AM | #8 |
Re: 36 window
i had to do this last month as the gear mechanism(regulator) had slipped(worn holding plate) and the window was at an angle and cracked(see pic below next post) so,with window in down position remove the roller(stud) guide that runs in radious slot it is on the window glass channell,then raise window fully up remove 8 mounting bolts you can now slide off the 2 raising arms from the window channel by moving left and right,leave mechanism in bottom of door for a mo,the glass and channell can now be removed as one by tilting window upwards, with window garnish surround removed!,then re centre window drive put 2 bolts back to hold,and wind mechanism until arms are parallel (horizontal) turn whole mechanism upside down in door, the window handle drive can be brought out first wiggle mechanism thru the door hole.
08-12-2010, 04:40 AM | #9 |
Re: 36 window
08-12-2010, 07:55 PM | #10 |
Re: 36 window
Thanks!!!!!!!!!!!!!! I can't tell you how much help this was for me.
08-13-2010, 05:29 AM | #11 |
Re: 36 window
Can you get me a closeup of what you have labeled "roller nut". My 36 came with no guts in the doors so I'm working with regulators and channels I had to buy. None of the parts I bought have a "roller nut" but there is the "tab" in the center of the channel with a hole drilled in it. What goes in the hole?
08-13-2010, 06:11 AM | #12 |
Re: 36 window
sorry its back in the car now, i stuck the labels on the computor screen of a saved pic, its called a stud and roller basically a headed stud with a roller on it, wescottsauto.com have them and all seals,felt window guides etc.phone 1-800-523-6279
04-11-2011, 12:35 AM | #13 |
Re: 36 window
Can't believe we all need the same thing but
Admiral, Would you please send my a copy also. Thanks [email protected] |
04-11-2011, 06:54 AM | #14 |
Re: 36 window
Admiral, looks like you may have a "best seller" going here ;-). I would also appreciate getting a copy. Just sent you a PM with my email address. Thank you!
04-11-2011, 07:38 AM | #15 |
Re: 36 window
These might help???
Wayne Last edited by wamnram; 03-20-2019 at 07:23 PM. |
04-11-2011, 08:47 AM | #16 |
Re: 36 window
Looks interesting - is that offset in the locating groove the mechanism that moves the window back before it moves it down?
Mart. |
04-11-2011, 01:49 PM | #17 |
Re: 36 window
Yes!
Wayne |
