Old 05-26-2020, 11:28 AM   #1
Lincolnville
Default What is this called?
Reaching out to the brain trust to find out what this item in the picture is called and where can I find some? Thanks in advance Matt
Lincolnville is offline   Reply With Quote
Old 05-26-2020, 11:32 AM   #2
160B
160B's Avatar
Default Re: What is this called?
I call it a "D" nut, in Brattons catalog they are called clinch nuts. They are on page 164 of the 2018 catalog under special hardware.
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 05-26-2020, 11:40 AM   #3
WTSHNN
WTSHNN's Avatar
https://www.brattons.com/catalogsearch/result/?q=clinch
or
https://modelastore.com/index.php?ro...ry_id=0&page=3
No one wants advice - only corroboration.
-John Steinbeck
WTSHNN is offline   Reply With Quote
Old 05-26-2020, 12:32 PM   #4
Dean Lemoine
Dean Lemoine's Avatar
I’ve never installed any, but I understand you’ll need some sort of special tool to install them.
Dean Lemoine is offline   Reply With Quote
Old 05-26-2020, 03:10 PM   #5
Big hammer
Back up the D-nut with a bucking bar, Then with a ball peen hammer peen it over. All you want the D-nut to do is not turn or fall out. That's if you have room to swing the hammer, if not use a C clamp with a large ball bearing and again hopefully you can reach with hole. If these don't work, if you get steel D-nuts you could tack weld them. All else fails JB weld.
get a bigger hammer tap done
Big hammer is online now   Reply With Quote
Old 05-26-2020, 04:16 PM   #6
Werner
Werner's Avatar
I fixed these nuts with contact adhesive before assembled.
Beste Gruesse aus Deutschland,
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 05-26-2020, 05:49 PM   #7
burner31
burner31's Avatar
Big Hammer: I'm going to copy this into my info file for later reference, excellent
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 05-27-2020, 08:03 AM   #8
Badpuppy
I never used weld or adhesive. Just pulled them into place with a screw and fender washer. They're snug enough they don't go anywhere.
Badpuppy is offline   Reply With Quote
Old 05-27-2020, 08:08 AM   #9
Jack Shaft
Or drill the hole square and use a nutsert..not show quality
Jack Shaft is offline   Reply With Quote
Old 05-27-2020, 08:24 AM   #10
jhowes
Jack shaft; i have drilled numerous holes and not one came out square. How do you do that? Jack
jhowes is offline   Reply With Quote
Old 05-27-2020, 08:45 AM   #11
Steve Plucker
Hey Jack...What is your secret on drilling a square hole!!!
Pluck
Old 05-27-2020, 09:07 AM   #12
100IH
The Asians have mastered the square hole task and there are videos on u tube.
100IH is offline   Reply With Quote
Old 05-27-2020, 09:09 AM   #13
Steve in Denver
Steve in Denver's Avatar
Use a square drill bit
Steve in Denver is offline   Reply With Quote
Old 05-27-2020, 09:33 AM   #14
Purdy Swoft
Purdy Swoft's Avatar
Drill a round hole and use a small square file to create the four square corners .
Old 05-28-2020, 11:36 AM   #15
Bob Bidonde
Bob Bidonde's Avatar
Broaching is the process of manufacturing precision odd shaped holes including square and rectangular ones. The "D" holes in sheet metal are punched.
https://www.youtube.com/watch?v=6XIQy6Mon54
https://www.youtube.com/watch?v=WY8948_de04
Bob Bidonde
Old 05-28-2020, 07:00 PM   #16
Synchro909
Synchro909's Avatar
My father was an excellent toolmaker and engineer/machinist. At one time, he worked for a company that amongst many other things, used to draw wire. the process was to pull a thicker piece of wire through a die with a slightly smaller hole in it. The wire stretched as it came through the die and you ended up with a smaller diameter wire. The dies obviously had to be very hard to last long. They used carbide. Now, the challenge! Try drilling even a round hole in that, then try making a square or rectangular hole in it, then polish it. He did many. (Imagine making the hole then polishing it for the finest strand of wire you have ever seen. They went down to less than 0.001")
I was intrigued, even as a kid to see him do it. It was a slow process. A mask was made of an insulating material with an appropriate hole in it. The mask was clamped to the surface of the block of carbide and a moving electrode set in motion in the hole. It would wander randomly around within the hole in the mask, making sparks as it went. Gradually the carbide was eroded till the hole went right through. Then came the arduous task of polishing the inside of the hole. Electric Discharge Erosion is not new but sometimes, even now is the only way. A friend once broke off a tap in a hole. EDE was the only way to save the component. (with a of of patience)
A square hole in mild sheetmetal? NO PROBLEM.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 05-28-2020, 08:39 PM   #17
hop up
hop up's Avatar
Broaching we do for key ways and heavy materials,In model making we used a number of different technique. Now mind you this was years ago before fancy expensive technology. A chassie punch came in many shapes as well as adel tool for cutting small squares or key ways in sheet metal .
Wanted flathead speed equipment Thanks
hop up is offline   Reply With Quote
Old 05-28-2020, 09:20 PM   #18
SteveB31
SteveB31's Avatar
It is called a D nut. Available in 10/32, 12/24, 1/4-20, 3/8-24, and 7/16-20. Available at Modelastore.com.
SteveB31 is offline   Reply With Quote
Old 05-29-2020, 01:26 AM   #19
CPatton
I use a hack saw to cut a few notches in the raised lip of the nut then I can pinch the lip over with vice grips or bendit over with a hammer.
CPatton is offline   Reply With Quote
