12-06-2010, 08:52 PM | #1 |
aluminum flywheel
Who else sells aluminum flywheels for the flathead? I wanted to get that one in the Speedway book but thay have been on back order for months. Somebody else must sell them. Thanks Walt
12-06-2010, 09:34 PM | #2 |
Re: aluminum flywheel
Google Wilcap...old supplier, quite expensive
12-06-2010, 09:36 PM | #3 |
Fidanza flywheels, the one I was looking at has the steel replaceable insert,
rather than the bare aluminum face, the last price I seen was around 300 dollars, sounded like the best deal I don,t remember exactly what seller had them, Ill look and let you know, I really want a lighter steel flywheel for my blown engine, someone on the old ford barn bought a steel one that was lighter than stock, I would like to know where they got it. Regards, Fordestes |
12-06-2010, 09:56 PM | #4 | |
plenty of used ones for sale cheap and they are easy to redrill to fit the Ford crank. Gear drive starters are readily adapted. |
12-06-2010, 10:15 PM | #5 |
Flat-O-Matic sells the Fidanza.
rich |
12-06-2010, 10:30 PM | #6 |
the sbc , that pete has suggested. Fordestes |
12-06-2010, 11:16 PM | #7 |
Walt speedway sells two different alm. flywheels for flatheads look at #91015625 @ $280.00 112 teeth 12 lbs. in stock. jack
12-06-2010, 11:54 PM | #8 |
Walt ,I found a fidanza with steel insert , for 319.00 ,check out Titan motorsports.
on line or the tel.# 407-277-8423 . let us know how you do on this deal I am going to order the fidanza, from titan,sounds like a real good deal. Fordestes |
12-07-2010, 06:52 AM | #9 |
I have a stock flywheel turned down, weighs about 22#, seems to work good. It's has lots of miles on it on works fine. Makes my 286 rev like it is an overhead.
