10-20-2010, 01:56 AM | #1 |
Powder Coating Heads
Anyone ever have any experience powder coating cast iron heads ('36)? Does the powder coating cause any cooling problems?
Tom |
10-20-2010, 03:50 AM | #2 |
Re: Powder Coating Heads
I do not know if the powder coating can take the heat.
10-20-2010, 03:58 AM | #3 |
I had my heads powder coated and they are holding up good I am sorry i did not have them coated on the inside as well. Jack
10-20-2010, 04:04 AM | #4 |
I had an Indian motocycle with powder coated barrels. [Air cooled motor] This machine was also stroked, and I had no problems from the powder coating. Brian
10-20-2010, 04:39 AM | #5 |
Did my 35 heads and intake this past spring, with no problems. Chet/Ma.
10-20-2010, 08:12 AM | #6 |
10-20-2010, 08:26 AM | #7 |
Gasoline or oil leaks may/will discolor the powdercoat and you can't do anything about it.
10-20-2010, 10:30 AM | #8 |
Wouldn't that hold in more heat?
Obsessed with all things 1936 Ford since birth... thanks Dad. |
10-20-2010, 10:38 AM | #9 |
No it was more like alum. color. I have had no issues with heat. And as far as staining goes, even the alum. cast head will stay stained from gas or oil. The only draw back is the bucks that it cost. Chet/Ma.
Thread Tools | |
Display Modes | |
