Old 07-28-2010, 12:21 PM   #1
jack39nyc
Default water pumps
Hi Fordbarn, I am removing my water pumps to have them modified by Skip,
the pumps are also the front motor mounts. What is the best way to support the motor while the pumps are out? thanks
jack39nyc is offline   Reply With Quote
Old 07-28-2010, 12:58 PM   #2
Vic Piano
Vic Piano's Avatar
Default Re: water pumps
I always use a bottle jack with a 2x4 between the jack and the front of the oil pan. Just jack up the engine enough to get the pumps free, don't forget to remove the bolt inside the pumps.
Imagination is more important than knowledge.
Vic Piano is offline   Reply With Quote
Old 07-28-2010, 01:13 PM   #3
Bruce Lancaster
I use a phone book as a stout, soft, and flexible pad between jack and pan.
Old 07-28-2010, 01:15 PM   #4
jack39nyc
Hi Vic, thanks for the reply I was not sure if I could use the old pan. Thats the way we did it back when, but I did many things the wrong way.
Thanks again,
Jack
Old 07-28-2010, 01:16 PM   #5
jack39nyc
Hi Vic, thanks for the reply I was not sure if I could use the oil pan. Thats the way we did it back when, but I did many things the wrong way.
Thanks again,
Jack
Old 07-28-2010, 01:21 PM   #6
jack39nyc
Bruce, phone book I like thanks. I love this place Fordbarn lives on.
Jack
Old 07-28-2010, 01:47 PM   #7
Bruce Lancaster
Just remember to write all the numbers you might need while the pumps are on vacation on the wall...
Old 07-28-2010, 02:08 PM   #8
GreenMonster48
GreenMonster48's Avatar
I also used Bruce's suggestion of the phone book when I did the pumps on my truck. Worked out very well....I'll just have to save one or two since phone books will probably be obsolete sooner than later.
GreenMonster48 is offline   Reply With Quote
Old 07-28-2010, 02:45 PM   #9
Vic Piano
Vic Piano's Avatar
The phone book is a good idea, I never thought of that.
Old 07-28-2010, 03:22 PM   #10
Newaygo Kid
When I did my pumps I made a jig out of 2x4s think of an upside down u. I made it so the short upright 2x4s would sit on the bolt flange of the oil pan. It works great if you need dimensions pm me. You only need one jack in the middle. Chris
Newaygo Kid is offline   Reply With Quote
Old 07-28-2010, 09:38 PM   #11
G.M.
Whatever you use keep it up on the front edge of the pan. A short 2X4 that don't go from side to side or a phone book in the middle of the pan could allow the pan to get a dent in it. G.M.
www.fordcollector.com
Old 07-29-2010, 06:15 AM   #12
Newaygo Kid
G.M. we use the 2x4s made up like an upside down u that goes near the front of the pan the two bys lift the engine and you put the jack in the middle of the u. You can leave the engine jacked up while you wait for your pumps to get repaired nothing ever touches the middle of the pan Chris
Old 07-29-2010, 06:51 AM   #13
jack39nyc
I got my pumps out ok thanks for your help everyone. I used the phone book and 2x4. Vlc thanks for reminding me about that bolt in side the bottom inlet.
jack
