07-01-2021, 11:51 AM | #1 |
Windows won't roll up
The driver side window in my "31 Delux Coupe will roll down just fine, but it is tough to get it to roll up.
Before I dig into it, can someone forewarn me of the parts/mechanism that may be the culprit? |
07-01-2021, 12:01 PM | #2 |
Re: Windows won't roll up
Pull the door panel off and look for a broken spring. or anything bent
07-01-2021, 12:38 PM | #3 |
My drivers window (30 Tudor) does that, and it's a slightly bent regulator arm. The arm sometimes catches on a door cross brace. I really don't want to take the whole thing apart, so I've been living with it. My eventual plan is to take it out and re-bend it, or double up the arm if it's weakened somehow with a metal strip riveted on.
07-01-2021, 01:08 PM | #4 |
