11-19-2022, 09:22 PM | #1 |
What Auto-Lite heater bolts to use?
I have the Auto-Lite heater that has two bolt holes which have both come out somewhere along the way. What do I get to replace and who sells it? Can’t find anything on Snyder’s or Bert’s.
Most grateful indeed… |
11-19-2022, 10:43 PM | #2 |
Re: What Auto-Lite heater bolts to use?
Are you referring to the bolts that hold the cover down?, if so I will have to check when I get home but I think they are something like1/4”X 3(?). Like I said I will check mine when I get home.
Mike
1930 TownSedan (Briggs) 1957 Country Sedan |
11-20-2022, 06:54 PM | #3 |
Same bolts as the oil pan only use with lock washers.
11-20-2022, 06:59 PM | #4 |
Yes, to hold the cover down.
Thanks so much indeed. |
11-20-2022, 07:01 PM | #5 |
Do you know what size they are?
11-20-2022, 07:18 PM | #6 |
www.whidbeymodelaclub.com |
11-20-2022, 10:05 PM | #7 |
11-20-2022, 10:24 PM | #8 |
I have the manifold and the shell that goes over it, with a broken bolt and I'm considering drilling and tapping it out and using a SS stud in place of a bolt with a nut and washer. It is very common to see manifolds with a broken bolt. The rust really locks them up and the heads twist off. Anybody ever try this? and how did it work?
Terry |
11-21-2022, 12:07 AM | #9 |
We, being RHD can't use those heaters but from what I've seen of them, wouldn't they get too hot for a lock washer? They are part of the exhaust manifold and so get close to red hot. I suspect that would be hot enough for them to go soft. Maybe, because I have never seen one, I am wrong but I'm sure they get HOT.
If I'm wrong, I will not drop my bottom lip if you say so.
