09-18-2013, 06:44 PM | #1 |
Dip stick
AllAt the recent car show at Orchard Beach, The Bronx NY, 3 model A 's were there and nobody was able to answer .....what is the proper depth that the oil dip stick is to go in. None of ours had a stop on it and I have been putting mine in all the way to the neck.
Please advise on the proper depth. With 5 quarts and the stick all the way in , I get a full reading on the stick. |
09-18-2013, 06:47 PM | #2 |
Re: Dip stick
I was taught that the dipstick goes all the way in, as far as it can go.
09-18-2013, 06:48 PM | #3 |
Re: Dip stick
All the way in.
09-18-2013, 06:59 PM | #4 |
Re: Dip stick
Dimensions from the full line to the handle bottom were given in the past and I measured mine to also give an answer, but don't recall the exact dimension right now. A "SEARCH" might turn up the thread with the answer.
09-18-2013, 08:48 PM | #5 |
Re: Dip stick
All the way in. And don't forget to fit the "other" end (the short stub below the loop) into the block, as well, to ensure a true reading.
09-18-2013, 08:50 PM | #6 |
Re: Dip stick
"They can make me grow older, but they CAN'T make me grow up!" |
09-18-2013, 09:19 PM | #7 |
Re: Dip stick
[QUOTE) The reprint 1930 Owner's manual I have says to be sure both prongs of the dip stick are fully inserted, as far as it will go, so I would say just stick it in until it won't go any further.[/QUOTE]
That's what she said also, Sorry I just could not Refrain. |
09-18-2013, 10:14 PM | #8 |
Re: Dip stick
09-19-2013, 06:26 AM | #9 | |
Re: Dip stick
Sorry I just could not Refrain. [/QUOTE] "BA-RUMP-BUMP"!! Check out "Tom The Dancing Bug" today on GoComics.com.
09-19-2013, 09:15 AM | #10 |
Re: Dip stick
All the way in is a good idea with most things in life including dip sticks. However, over the years you never what has happened. Are you sure you have a correct dipstick ? If not, then after an oil change [ 4 qts] just file a mark on the stick. If the pan is ever removed for cleaning and 5 qts installed then check the mark and correct it if needed.
09-19-2013, 09:22 AM | #11 |
Re: Dip stick
I have found in the past, discrepancy's in the markings from a repo dip stick as compared with original dip sticks. Oil level half way between L & F is just fine.
09-19-2013, 11:38 AM | #12 |
Re: Dip stick
That's where mine stays.
09-19-2013, 07:36 PM | #13 |
Re: Dip stick
Where is the discrepancy between 4 and 5 quarts. Why do some books say 5 and others 4 qts ?
09-19-2013, 08:02 PM | #14 | |
Re: Dip stick
Sorry I just could not Refrain. [/QUOTE] Glad i aint the only one with a mind in the gutter
1929 Model AA - Need long splash aprons! |
09-19-2013, 08:28 PM | #15 | |
Re: Dip stick
the first fill would take 5 quarts and any oil change after that would take 4 quarts. Bob |
