Old 06-17-2013, 11:45 AM   #1
L-head
Default 31 coupe door glass
The Model A Service Bulletins list two different sizes for coupe door glass. Neither will fit the door of my 31 coupe. What are the correct measurements for a 31 coupe door glass?
L-head is offline   Reply With Quote
Old 06-17-2013, 12:31 PM   #2
Craig Lewis
Craig Lewis's Avatar
Default Re: 31 coupe door glass
The service bulletin chart does indead have an error in the first picture.
The first two lines under that first picture should be crossed out in everyones book right now. Picture #6 is closer to correct.
Also this chart is 1928 specs when coupe & tudor shared the same door glass...not the case in 30-31.
From the original NAGS list....your 31 coupe dr glass measures
25 1/16 x 15 7/16
On soapbox...for anyone who cares....cutting side & back windows from laminated safety glass might be fast and easy, but in the very unlikely case you wind up on the roof in a ditch with the windows inoperable....you'll never kick your way out.
Legally...
Only windshields, should be laminated safety glass.
All other windows should be tempered safety glass.
Every autoglass shop can get you tempered glass.
Off soapbox...
Craig Lewis is offline   Reply With Quote
