10-18-2011, 05:14 PM | #1 |
Light switch rod - rattles to distraction
When I attach the light switch spider, spider spring and spider retainer on to the light switch rod, the horn button/light switch handle is flush with the top of the steering wheel. But when I attach the light switch body and bail, it pushes the light switch rod up so that the horn button/light switch sticks up about a quarter of an inch. Then when driving it starts to rattle and drives me crazy. What is the cause and is there a fix? This happened after having someone rebuild the steering box ( 2 Tooth on a 30 town sedan ).
10-18-2011, 06:23 PM | #2 |
Re: Light switch rod - rattles to distraction
Light rods come in different lengths. Are you using the same one you used before the rebuild, or did you buy a new one? Do you have an early 30 with a 29 setup?
10-18-2011, 06:45 PM | #3 |
Am using the same one that was on there before the rebuild. Everthing looks perfect before I put on the light switch body, - I even tried a different light switch body upper half but it made no difference.
10-18-2011, 06:50 PM | #4 |
Do the lights work when the rod pops up?
10-18-2011, 09:49 PM | #5 |
Yes - horn & lights work.
10-19-2011, 08:43 AM | #6 |
Paul in CT |
