11-03-2021, 07:16 AM | #1 |
Which application for BW Pcv382?
This is a question on behalf of anyone considering switching to pcv on an 8ba. The recommended valve is BW pcv382, however it's no longer available. A search on BWs site as well as trying to cross reference the number provided no info. My question is, what is the original application the valve came on? I'm sure someone still makes the correct valve so looking it up by application would make the process easier. Thanks in advance
11-03-2021, 08:04 AM | #2 |
Re: Which application for BW Pcv382?
Application of BORG WARNER PCV382
Make Model Engine Type Year FORD ESCORT L4-1.9L PCV Valve - 1992 MERCURY TRACER L4-1.9L PCV Valve - 1992 Brand:BORG WARNER Part Number(s):PCV382 ProductName:PCV Valve Cross Interchange Parts Factory Number AutoZone FV343 MasterPro 2-9749 MasterPro 9749 HAVOLINE P157 AUTOTUNE PT38000 FILTERS INC 261 |
11-03-2021, 08:06 AM | #3 | |
11-03-2021, 08:08 AM | #4 |
Great! :-))
Glenn |
11-03-2021, 08:13 AM | #5 | |
11-03-2021, 08:23 AM | #6 |
11-03-2021, 08:24 AM | #7 |
"Why would anyone recommend using a valve that is used on an engine with half the displacement of a flathead ?"
Because it often works. I have one for a 3L 183CI, PCV333 displacement on my 268CI 59A and it works great. No oil fog on the firewall and a smaller effect on the carburetor settings, i.e. it sucks less ;-) Last edited by glennpm; 11-03-2021 at 08:40 AM. |
11-03-2021, 08:31 AM | #8 |
I have always used SBC ones for a 283 with no ill effects, and works fine. It is just a 1 way check valve for a similar displacement. It also is nice and small.
11-03-2021, 08:33 AM | #9 |
A lot of people use one from a Jeep 4.0. I don’t have a part number. It sure sounds like Glenn is talking from experience, PCV valves aren’t expensive. Maybe try both……. Mark
11-03-2021, 08:38 AM | #10 |
11-03-2021, 08:46 AM | #11 |
Jeep 4.0L arent actual pcv valves. They have what look like two in the valve cover but The front one is fully opened and the rear one has a small hole on the bottom but has no valve inside so technically it's opened as well
11-03-2021, 08:52 AM | #12 |
Now that we have the valve itself selected, does anyone have a part number or application for the grommet that goes into the road draft port?
(I'm late to the party because, few years ago, I had my road draft tube and clamps chrome plated. Unfortunately, they came out beautifully.) |
11-03-2021, 08:55 AM | #13 |
Speaking of a 4.0L, I wonder how a 4.0L explorer valve would do?
11-03-2021, 09:33 AM | #14 |
This is the one I am using along with associated grommet.
( Dodge 3.9L) from Napa---------- https://www.napaonline.com/en/search...lve&referer=v2
11-03-2021, 09:43 AM | #15 | |
11-03-2021, 09:52 AM | #16 | |
Been running perfectly for 10 years plus.
DON'T RECALL DOING SOMETHING FOR MYSELF BASED ON SOMEONE ELSE'S LIKES OR DISLIKES Last edited by 51 MERC-CT; 11-03-2021 at 10:00 AM. |
11-03-2021, 12:09 PM | #17 |
I remember reading a few of your posts on it now. What vehicle did you tell them at the parts place or do you have a number for the valve and the grommet you're using?
11-03-2021, 12:46 PM | #18 |
Now that I think about it, maybe it was the grommet from the Jeep with a different PCV….. did you check different year Jeep’s?……. Mark
11-03-2021, 01:03 PM | #19 | |
https://www.dormanproducts.com/c-544-pcv-grommets.aspx This list became our "go-to" source when building a PVC Valve system for Heard's brand-new, modified 8BA engine for his '35 pick-up truck. This DORMAN list was priceless when it came to choosing a fitting to hold the PCV Valve we were using, as well as to fit a piece of copper tubing, as needed for our system. The DORMAN catalog also gives full SIZING information with each piece. The piece below shows what we needed, as well as the GM PCV Valve used. We had decided to build a system that would hide the ugly PCV Valve as well as MOST of the plumbing, yet allow servicing or replacement of the PCV Valve WITHOUT REMOVING the intake manifold to do it. Click the LINK BELOW for a detailed thread on the entire project, with many pictures, diagrams and PARTS LIST! DD https://www.fordbarn.com/forum/showt...pman+pcv+valve . |
11-03-2021, 01:24 PM | #20 |
I'll have to check the valve for a 4.2. I'm actually in the process of a 4.0L swap in my '89 YJ that that has/had a 4.2. I also did the same swap in an '84 and '86 CJ7 that had the 4.2 but I never gave the PCV valve a second thought.
