Old 05-25-2019, 03:12 PM   #1
Stretch Cab
Stretch Cab's Avatar
Default Where do these rods go? 1936 Fordor
I’m working on my chassis and have found two rods attached in front of the rear motor mounts on both sides of the frame. They are factory installed with a flat round head bolt flush with the frame and a square opening for tightening. The head of the left rod is shown on pg 82 of the 35/36 Ford book put out by the Early Ford Club. My bolts are cut off about 4” from the frame. What were these bolts used for?
Sorry for no picture I’m not at home to use my computer.
Let us live so that when we come to die, even the undertaker will be sorry. Mark Twain
Stretch Cab is offline   Reply With Quote
Old 05-25-2019, 03:29 PM   #2
my4dv8
Default Re: Where do these rods go? 1936 Fordor
Sounds like engine steady rods. they go through round bosses on the rear of the block and are held by castellated nuts . As yours have been cut ,you may need to put a listing in the wanted section on here.
my4dv8 is offline   Reply With Quote
Old 05-25-2019, 03:34 PM   #3
VeryTangled
VeryTangled's Avatar
Hi Everyone. Stretch Cab, I believe you are describing the 'stay rods,' 'anti-chatter rods,' or 'steady rods' that were designed (I think) to supplement the rear engine mount to increase longitudinal stability. The rear end is attached to the frame as you describe, the front end goes through the engine block.
-Jeff H
Have you thought about supporting the Early Ford V-8 Foundation Museum?
VeryTangled is offline   Reply With Quote
Old 05-25-2019, 06:52 PM   #4
19Fordy
19Fordy's Avatar
They look like post #5 here.
https://www.fordbarn.com/forum/showt...i+chatter+rods
Old 05-25-2019, 08:27 PM   #5
mercurycyclone
See attached.
File Type: jpg 9A2472D9-3311-480D-B79F-52B492C050D6.jpg (59.1 KB, 220 views)
mercurycyclone is offline   Reply With Quote
Old 05-30-2019, 02:52 PM   #6
Stretch Cab
Thanks for the help. I guess someone decided they were not needed years ago and cut them off.
I changed my search to the motor area of the 35/36 Ford book and they were listed there.
Old 05-30-2019, 08:25 PM   #7
Cool Hand Lurker
Cool Hand Lurker's Avatar
When the rear wheels start moving the car the force is movind forward by way of the rear axle, torque tube, transmission and engine. The transverse rear spring will flex a bit fore and aft, allowing the force to be resisted only by the front motor mounts and crossmember. The rods you are asking about transfer the force to the frame behind the transmission area.
In later models with the open drive shaft the spline shaft is allowed to move fore and aft so there is no force transferred to the transmission and engine.
Cool Hand Lurker is offline   Reply With Quote
Old 04-21-2020, 10:09 AM   #8
Tom's36coupe
Tom's36coupe's Avatar
Putting my 59AB motor back in the 36 coupe and I don't have them .My car has the closed drive shaft standard rear end setup. Anybody make them or know who sells a set? Thanks!
Tom's36coupe is offline   Reply With Quote
Old 04-21-2020, 10:52 AM   #9
JM 35 Sedan
JM 35 Sedan's Avatar
So many of those steady rods were left off or cut off back in the day. Also, when original engines were replaced with the later 8ba engines, there was no provision on the bolt on bell housing to accept steady rods so they were probably just tossed after that. I doubt anyone is reproducing them, but I have seen home made versions. I see used sets advertised for sale here, on other internet website's, and at fleamarkets all the time. I'm sure there are NOS sets to be found and had.
I'm moving all of my old Ford parts collection now to a new location, and have found several sets I didn't even know I had
John
Old 04-21-2020, 12:39 PM   #10
V8COOPMAN
V8COOPMAN's Avatar
This pic shows how the rods attach on either end. Their function is to restrict fore/aft movement of engine/trans as torque tube exerts extreme forces on the assembly when releasing clutch, as well as while sustaining normal cruise. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 04-21-2020, 07:31 PM   #11
terry
The concept was still hazy for me till you showed this picture. Thanks coopman. Terry
terry is offline   Reply With Quote
Old 04-22-2020, 10:50 AM   #12
Don Rogers
Don Rogers's Avatar
Most likely you will need the longer rod (48- 6044) as shown below.
Don Rogers is offline   Reply With Quote
Old 04-22-2020, 11:03 AM   #13
rotorwrench
rotorwrench's Avatar
Ford used radius rods on anything that might move around too much other wise. The rear engine mount rubber can deteriorate to the point that the drive train will push the motor forward more than it should and this was the fix in the prewar model B & V8 era. Ford engineers felt that the later post war rear engine mount design was good enough that it was no longer needed in the 59 era but they really should have kept them.
Old 04-22-2020, 12:39 PM   #14
V8COOPMAN
V8COOPMAN's Avatar
Well, you should remember that they DID retain this basic concept on Canadian-built cars. DD
T5 W/TORQUE TUBE
Old 04-22-2020, 06:06 PM   #15
Joe KCMO
Joe KCMO's Avatar
The purpose of the rods was to prevent the clutch from losing friction with the pressure plate when reversing. The rear wheels connected to the transmission my the drive shaft tube in reverse would kink the clutch causing slip. My 39 with an 8BA would not go in reverse on a slight incline because they were missing. Had to install so could go in reverse anywhere. You need them!
Joe KCMO is offline   Reply With Quote
Old 04-22-2020, 06:15 PM   #16
Joe KCMO
Joe KCMO's Avatar
You can also make your own by welding a bolt perpendicular to the end of a threaded rod. Does not have to be threaded entire length. Will not get you a Senior badge at Hershey, but will definitely work and do it’s intended job. That’s what’s on my 39 with an 8BA, same for any 8 in the 30’s.
Old 04-22-2020, 06:22 PM   #17
Joe KCMO
Joe KCMO's Avatar
Error found.
Old 04-23-2020, 09:21 AM   #18
rotorwrench
It's not just reversing that can suffer problems. The clutch linkage can get stressed either way. I've seen kits that have a support that attaches at the transmission bell flange but they only use a single rod to hold things solid. Here is a link to an old thread.
https://fordbarn.com/forum/showthread.php?t=254926
