Old 09-21-2011, 07:16 AM   #1
38V8
38V8's Avatar
Default Intake manifold and air cleaner color '51?
What was the factory color for the V8 intake manifold in '51, and the color for the air cleaner? I've seen some black, some silver/aluminum intakes, along with a light blue metallic color for the air cleaner, and some of those even black. Not sure which is the correct factory stock color combination for these parts that was with the stock bronze block and head color. Thanks!
38V8 is offline   Reply With Quote
Old 09-21-2011, 07:39 AM   #2
flatheadfan
flatheadfan's Avatar
Default Re: Intake manifold and air cleaner color '51?
'51 air filter and intake - Bronze!
flatheadfan is offline   Reply With Quote
Old 09-21-2011, 07:57 AM   #3
proxie35
proxie35's Avatar
Smile Re: Intake manifold and air cleaner color '51?
The engine, air cleaner,oil filter & starter were Hawaiian Bronze. The following
items were Black.
Oil filler cap & tube
Crankcaes vent tube & clamp
Fan assembly & pully
Generator, mount & strap
Exhaust crossover pipe
Coil & bracket
Plug wire stands
(THERMOSTAT HOUSINGS) were Black, they were NEVER Bronze from the factory. Sherrel
proxie35 is offline   Reply With Quote
Old 10-06-2011, 05:36 PM   #4
ora masters
items were Black.
Coil & bracket
Plug wire stands
35 you are right on
ora masters is offline   Reply With Quote
Old 10-06-2011, 05:46 PM   #5
jdl
jdl's Avatar
Send a message via ICQ to jdl
items were Black.
Coil & bracket
Plug wire stands
Very good... except the vent tube clamps were ford blue, the engine paint was bronze, Hawaiian bronze was a body color, starter was also bronze. GOOD JOB
jdl is offline   Reply With Quote
