Old 05-17-2021, 07:15 PM   #1
maicu
Default 1933 Ford gearbox
Hello, Its possible use a 1932 Ford v8 gearbox into my 1933 Ford V8? I haven´t the 33's gearbox so I have a 32. Can I use it without modiffications?
Thanks in advance.
maicu is offline   Reply With Quote
Old 05-17-2021, 09:17 PM   #2
DavidG
DavidG's Avatar
Default Re: 1933 Ford gearbox
Other than the different separate rear mounting arrangements, the '32 shift lever housing having provision to attach the hand brake, and some inconsequential differences in the case casting depending on when the '32 case was manufactured, they are identical inside and out.
Old 05-18-2021, 12:04 AM   #3
Brian
Brian's Avatar
But isn't the rear mount different?
Old 05-18-2021, 01:26 AM   #4
DavidG
DavidG's Avatar
Could have sworn that's what the first eight words in #2 conveyed.
Old 05-18-2021, 05:28 AM   #5
Mac VP
Mac VP's Avatar
The clutch release arm changed between 32 and 33, but the arm could be swapped over from one to the other.
VANPELT SALES LLC
Cincinnati, Ohio
Office: 513-724-9486
www.vanpeltsales.com
www.classictransmission.com
Mac VP is offline   Reply With Quote
Old 05-18-2021, 09:06 AM   #6
maicu
Thanks DAVIDG, have you pics of these two gearboxes to see the diferences? or any link?
Thanks to all
Old 05-19-2021, 06:06 AM   #7
deuce lover
deuce lover's Avatar
Here is a link to a bare gearbox on EBAY. The '32 shift tower has provisions to attach the E brake handle.'33's do not . Post a picture of what you have might be easier .
https://www.ebay.com/itm/12468726731...MAAOSwRUpgfLzo
Old 05-19-2021, 11:24 AM   #8
rotorwrench
rotorwrench's Avatar
The rear bearing retainer should be changeable between the two so that the later rear mount can be used. Most of them can be swapped around depending on application. The hardware for the mount needed may have to be used since that stuff might vary with some applications. I didn't have any problem putting a 1932 rear mount on a 1939 transmission to use in an AV8 cross member based on a 1932 K-member. The same early bearing retainer was used for a number of years before it changed.
It's easy to fabricate a mount for an E-brake control assembly. A piece of angle iron whittled down to fit worked well for me. It bolts to the side of the shift tower and is drilled for the E-brake handle & ratchet.
For a 1933, very little change should be necessary. Basically just the rear mount.
Old 05-19-2021, 12:13 PM   #9
DavidG
DavidG's Avatar
And the clutch release lever.
Old 05-20-2021, 11:37 AM   #10
deuce lover
Here is the difference in the clutch release lever.First pic is the '32,second is the 33-34.
