Old 05-05-2021, 01:05 AM   #1
buddyholley19
Default 29 Tudor Front Driver side window issue.
Question regarding the window ,The window will crank up but will slip. I have to help it buy pulling up on the glass with my hand while I roll up the handle. Any tips on what I should look for thanks in advance.
buddyholley19 is offline   Reply With Quote
Old 05-05-2021, 01:14 AM   #2
J Franklin
J Franklin's Avatar
Default Re: 29 Tudor Front Driver side window issue.
There might be a stripped tooth in the gears.
Old 05-06-2021, 01:15 AM   #3
Ivan in southeast va.
Ivan in southeast va.'s Avatar
Just needs a new regulator, easy fix.
Ivan in southeast va. is offline   Reply With Quote
