Old 08-30-2016, 04:33 PM   #1
Topsterguy
Topsterguy's Avatar
Default '36 Ford rearend - # of splines?
I want to use one of the Speedway kits to adapt the stock rearend in my 36 to an open driveshaft. They have one for a 6 spline and one for a 10 spline...which would the 36 use? Thanks!
Topsterguy is offline   Reply With Quote
Old 08-30-2016, 05:10 PM   #2
swanwaco32
Default Re: '36 Ford rearend - # of splines?
should be 10 spline
swanwaco32 is offline   Reply With Quote
Old 08-30-2016, 06:11 PM   #3
Topsterguy
Topsterguy's Avatar
Originally Posted by swanwaco32 View Post
should be 10 spline
Thanks! I want to order all the parts I need before I take the one in it apart.
Old 08-30-2016, 10:01 PM   #4
Topsterguy
Topsterguy's Avatar
should be 10 spline
Just looking at a parts site and they list the 10 spline for 32-24 and the 6 spline for 35-48...??
Old 08-30-2016, 10:02 PM   #5
Topsterguy
Topsterguy's Avatar
B-4209-A
Ring & Pinion Set - 3.78:1 ratio PIC 1932 early style car & pickup $ 395.00 B-4209-HS Ring & Pinion Set - 3.54:1 ratio PIC 1932 early style car & pickup 395.00 40-4209-F Ring & Pinion Set - 3.25:1 ratio - Ten spline pinion PIC 1932 late to 1934 car & pickup 495.00 40-4209-HS Ring & Pinion Set - 3.54:1 ratio - Ten spline pinion PIC 1932 late to 1934 car & pickup 495.00 68-4209-F Ring & Pinion Set - 3.25:1 ratio - Six spline pinion PIC 1935-48 car & 35-47 pickup 349.00 68-4209-HS Ring & Pinion Set - 3.55:1 ratio - Six spline pinion PIC 1935-48 car & 35-47 pickup 349.00 8C-4209-HS Ring & Pinion Set - 3.55:1 ratio PIC 1948-50 F1 pickup 349.00
Old 08-30-2016, 10:56 PM   #6
JM 35 Sedan
JM 35 Sedan's Avatar
If I am reading your question correctly, I believe you are asking for the pinion gear spline count for a stock '36 (coupe??) rear, and that would be 10 splines as swanwaco32 mentioned in his post......IF the rear in your car is actually stock, never been changed.
Now on your last post you posted a lot of information, apparently copied from Mac Van Pelts website. This information looks to me to be for reproduction gear sets, probably made in Italy, that he is selling as new replacement gear sets. These gear sets available for '35 -'48 vehicles with original banjo style rears, are reproduced with 6 spline gears. No one to my knowledge is making '35-'48 reproduction banjo style rear gears with 10 spline pinions.
If these repro gears are what you plan to use, then your only choice would be to use a set of these gears with a 6 spline pinion and buy the kit for an open drive that would be necessary for a 6 spline pinion.
If you are planning to use a stock used set of gears, either what's in your car now, or maybe purchase another used set of gears in the preferred ratio, then depending on what that pinion spline count is, will dictate which spline count kit you will need to buy from Speedway.
Hopefully, this is clearer than mud .
John
Old 08-30-2016, 11:31 PM   #7
Topsterguy
Topsterguy's Avatar
No on your last post you posted a lot of information, apparently from Mav Van Pelts website. This information looks to me to be for reproduction gear sets, probably made in Italy, that he is selling as new replacement gear sets. These gear sets available for '35 -'48 vehicles with original banjo style rears, are reproduced with 6 spline gears. No one to my knowledge is making '35-'48 reproduction gears with 10 spline pinions.
If these repro gears are what you plan to use, then your only choice would be to use a set of these gears with 6 spline pinion and buy the kit for open drive that would be necessary for a 6 spline pinion.
If you are planning to use a stock used set of gears, either what in your car now, or maybe purchase another used set of gears in the preferred ratio, then depending on what that pinion spline count is, will dictate which spline count kit you will need to buy from Speedway.
That's what I'm asking, and I didn't mean to sound like I was questioning swanwaco32's answer at all , I just read the other info and wondered...now it's clearer. The rear end in my coupe is the stock 36 that came in it from the factory, never changed, and I want to keep it complete with the gears in it. Thatnks very much for the info.
Old 08-30-2016, 11:51 PM   #8
Kahuna
Kahuna's Avatar
I would recommend you buy the open drive kit from "Hot Rod Works" in Idaho.
Excellent quality & fit
JMO
Jim
Kahuna is offline   Reply With Quote
Old 08-31-2016, 07:35 AM   #9
JSeery
JSeery's Avatar
JMO
Jim
I second Kanuna on Hot Rod Works, they sell quality parts. Give them a call. And on the spline count, if I was doing this job I would remove the torque tube and count them. You can get your kit within a very short time and that way you know what you actually have!
Old 08-31-2016, 12:44 PM   #10
cubflyer
I third that on hot rod works excellent quality,and good people, cubflyer
cubflyer is offline   Reply With Quote
