Old 10-09-2011, 07:28 AM   #1
mike d
Default flathead back firing
i have a 59ab that is backfiring on mild accelleration, crab dist with msd 6a box. i'm using only one set of point for a trigger. stock single carb with .051 jets. one wire alternator, idles at 450 rpm . should i have removed the condensor from the dist, or should i be looking somewhere else? thanks, mike
mike d is offline   Reply With Quote
Old 10-09-2011, 05:40 PM   #2
39portlander
39portlander's Avatar
Default Re: flathead back firing
I would be looking to your builder and If it's a crab dist. talk to bubba's ign. It's prob. something very simple
39portlander is offline   Reply With Quote
Old 10-09-2011, 06:06 PM   #3
BillM
BillM's Avatar
When triggering with one set of points you should be using the set that normally opens last; the trailing set. The timing will be off some if using the other set; not sure if that would be the cause of the problem but something to check.
My web page:
http://myplace.frontier.com/~wgmumaw/
BillM is offline   Reply With Quote
Old 10-09-2011, 11:09 PM   #4
Mr 42
Mr 42's Avatar
Are you using Resistor ignition wire's.
Ive heard that you can get "False" sparks if you use copper wires.
Check the MSD ignition manual and what it say's.
Mr 42 is offline   Reply With Quote
Old 10-10-2011, 03:03 AM   #5
ken ct
When you start throwing in non stock parts you kind of lose the stock guys ability to diagnose your problems,go to the HAM site,they would be better equipt to answer your ques. ken ct.
ken ct is offline   Reply With Quote
Old 10-10-2011, 07:42 AM   #6
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
I think BillM hit the nail on the head !!
The spark timing would be way off the correct rotor phase if the wrong set of points were being used. Also the crab cap is pretty prone to jump spark when output is high. I assume its a pretty stock engine so theres no need for high spark output. The distance between the cap and the aluminum crab case will arc with high voltage. Plugs should be at .025.
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 10-10-2011, 01:37 PM   #7
richard crow
BUBBAS IGN i offen woundered why ford switched in 46 to the other desine now after reading your post it makes cents ford must of had complants especaly on rainie days of spark jumping from cap to housing
richard crow is offline   Reply With Quote
Old 10-10-2011, 02:22 PM   #8
FlatheadTed
FlatheadTed's Avatar
Cannot think wny you would use the trailing set .The opsit is true .Trailing means last ?? You must use the points that open at 5 % in othere words its the set on the right facing the Grill
you must use the
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 10-10-2011, 04:33 PM   #9
ken ct
If FORD would have uses the rubber nipples on the caps 9 wires like i do the water would not have gotten in there.OMO. ken ct.
Old 10-10-2011, 08:39 PM   #10
BillM
BillM's Avatar
The coil fires when the primary current is interrupted, so with a stock dual point setup both sets of points must be open; therefore ignition happens when the last set of points opens and this is where the timing should be set.
My web page:
Old 10-11-2011, 03:28 AM   #11
FlatheadTed
Yes your right .First to load the coil but last to open
Old 10-11-2011, 04:50 AM   #12
JWL
To answer the original question---no, you do not need the condenser when using the 6A MSD control box. Look at the carb accelerator pump, ignition timing, etc. For a quick test, apply some choke during the periods of back fire and see if that makes any difference.
JWL is offline   Reply With Quote
Old 10-13-2011, 04:29 AM   #13
mike d
thanks guys mike
