04-03-2019, 02:53 PM | #1 |
Wiring diagram to see if motor runs?
I could use a simple basic wiring diagram to wire up a motor on a chassis thanks for your time Joe
04-03-2019, 03:00 PM | #2 |
Re: Wiring diagram to see if motor runs?
Battery to coil, coil to points
04-03-2019, 03:05 PM | #3 |
Does this help?
04-03-2019, 03:10 PM | #4 |
This might also help you out.
04-03-2019, 03:50 PM | #5 |
04-03-2019, 05:21 PM | #6 |
04-03-2019, 05:33 PM | #7 |
I really suggest anyone interested on this subject to watch Jackson YouTube video very good information!
04-04-2019, 09:49 AM | #8 |
Connect battery (and generator) to coil (-).
Connect points (through switch) to coil (+). Connect HT wire between coil and distributor cap. For negative ground, reverse coil (+/-) above. Last edited by Badpuppy; 04-05-2019 at 10:36 AM. Reason: For negative ground,,, |
04-05-2019, 03:33 AM | #9 |
and here's the simplest Model A ignition circuit ... which completely avoids ammeter and its wiring and switch and its wiring ( where short circuits or breaks could be causing problems). [PS ideally if ground is -ve then connect coil -ve to points. If ground is positive then connect coil+ve to points but it generally works OK even if coil polarity is incorrect!]
04-05-2019, 10:29 AM | #10 | |
04-05-2019, 10:42 AM | #11 |
04-05-2019, 10:45 AM | #12 |
The diagram in #3 is not the same as John's.
04-05-2019, 11:13 AM | #13 |
04-05-2019, 11:24 AM | #14 |
May be obvious to you Badpuppy, but not to everyone . I was just trying to help the OP.
04-05-2019, 07:50 PM | #15 |
I always carry the end of an old ignition cable to screw into the distributor which makes hot wiring easy.
