Old 01-25-2021, 12:16 PM   #1
Moesby
Default 1935 Ford ignition switch
I took my ignition switch out to replace brush inside. Pieces fell out on floorboard and I can’t figure out how to put it back together. 😂 Anybody have a detailed pic of how the pieces go back together?! Help wanted!🤷🏿www.jalopyjournal.net♂️ Thanks
Moesby is offline   Reply With Quote
Old 01-25-2021, 02:41 PM   #2
Terry,OH
Terry,OH's Avatar
Default Re: 1935 Ford ignition switch
The flat piece of metal goes on first with the small bent tab inserted into the rear slot of the ignition switch on/off lever. then the cup with the movable switch contact and finally the cover.
Old 01-25-2021, 03:03 PM   #3
petehoovie
petehoovie's Avatar
It's tricky to reassemble. The ignition switch contact brush pivots on the shoulder of the small hole in the bottom ignition switch housing. Now, place the terminal plate over the top of the housing. You'll have to find a way to hold the assembly together. I used a very thin ty-rap/zip-tie. After attaching the assembly to the column drop with the two screws, I cut and removed the ty-rap. See this thread > https://www.fordbarn.com/forum/showt...tch+reassembly
Old 01-25-2021, 04:42 PM   #4
Don Rogers
Don Rogers's Avatar
Here's an exploded view of the assembly done by Gary Tosel a while back.
Don Rogers is offline   Reply With Quote
Old 01-25-2021, 09:45 PM   #5
Tim Brown
Tim Brown's Avatar
Thats a great drawing. Printed for future reference.
Tim Brown is offline   Reply With Quote
Old 01-26-2021, 05:24 AM   #6
mercman from oz
mercman from oz's Avatar
Thanks Don for adding this very detailed Drawing to this Thread. It is very helpful.
mercman from oz is online now   Reply With Quote
Old 01-26-2021, 01:03 PM   #7
DavidG
DavidG's Avatar
Somewhat off topic, but that helpful diagram that Don posted is slightly different for '35-'36 phaetons and roadsters. The bolts attaching the housing to the dash insert from the bottom, not from the top and the holes in the housing are bored out to eliminate the threads. The part on the inside of the dash (18) came in two forms, the first being a hefty steel block with raised ends to clear the bottom of the speedometer and the second a steel stamping folded over to be of sufficient thickness to be threaded for the attaching bolts like the steel block. You can always tell a housing that was originally used on a phaeton or roadster as it lacks threads in the two attaching holes at the top.
